Old 03-07-2013, 09:31 PM   #1
UATahoe
Braided transmission oil cooler lines. Good source?
Looking to change out the tranny oil cooler lines during my transmission and motor swap. Any good suggestions or sources? I will be installing a transmission cooler and running it in series with the radiator trans cooler.
UATahoe is offline   Reply With Quote
Old 03-07-2013, 11:39 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Braided transmission oil cooler lines. Good source?
yOUR LOCAL HYDRAULIC HOSE & PARTS STORE ( THINK PARKER STORE OR EVEN JACKOVICH) CAN MAKE THEM UP FOR YOU.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-08-2013, 12:23 AM   #3
Gordonr1973
Home Built '87
Gordonr1973's Avatar
If you are able & want to take on a project, you can build them yourself.
Many videos on youtube how to do it, but best ones are from Koul Tool which is a little vinyl tool that helps sets the line into AN fittings.
I made lines for my truck for the forst time last winter and none leaked surprisingly enough!
So if I can do it I'm sure anyone can!! :-)
https://www.youtube.com/watch?v=IL4kPrSZSEc
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-08-2013, 09:54 AM   #4
v30crewcab
v30crewcab's Avatar
summitracing has all the parts. not hard to do.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 03-08-2013, 10:14 AM   #5
UATahoe
Thanks for the input guys. I will check out the video. I have never really dealt with fittings or building lines. May be fun to learn how. LOL. All the fitting sizes and types always seemed overwhelming.
Old 03-08-2013, 10:47 AM   #6
UATahoe
So what size or type of AN fittings would be needed? Line runs from the transmission into the radiator, out of the radiator, into the aux cooler, and out of the aux cooler back to the transmission.
Old 03-09-2013, 07:33 AM   #7
Gordonr1973
Home Built '87
I think they were 6's and 8's if memory serves....check out my build about Nov '11
Gordon
Old 03-09-2013, 07:45 AM   #8
ont_guy_38
ont_guy_38's Avatar
6an would be the same as the original lines. I would go here and do some searching as for what fitting you might need. http://www.holley.com/Index.asp?division=Earls
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 07-15-2013, 02:15 PM   #9
a men a truck a dog
Hi I was looking over this ??? Myself I have a 1986 c10 2wd 700r4 350 5.7 tbi. I tjink its best that I use the brsided lines save bending braking and craking worries from the traditional lines. Now that I have answerd that ??? Should have install a transmission cooler also. I hear you guys talking about them but I never had one. Is my setup ok without it, or am I at risk of burning up my 700r4
a men a truck a dog is offline   Reply With Quote
Old 07-15-2013, 02:53 PM   #10
a men a truck a dog
Ok so I did a little online search and found a company (jegs) that offers a braided line for the 700r4. They offer a ket that runs braided lines to a 18 or 20 inch jegs trans cooler and back to the trans. Braided lines and 20 cooler all for right under $250. I would like to get some information form you guys before I buy and install this set up
Old 07-16-2013, 12:19 AM   #11
LynnJr
AN lines are always hard to figure out so remember this little trick and no more worries.
Each number is about 1/16 inch.
-4 AN would be 4/16 or 1/4 inch hose
-6 AN would be 6/16 or 3/8 hose
-8 AN would be 8/16 or 1/2 inch hose
-16 AN would be 16/16 or 1 inch hose.
-24 AN would be 24/16 or 1.5 inch hose.
There are places online were you pick the right connector then the left connector then the type of hose you want and its length.They show you a picture of what the completed hose will look like then build it/them for you.
LynnJr is offline   Reply With Quote
Old 07-16-2013, 12:23 AM   #12
bigblock73
yeller
bigblock73's Avatar
Here is a great link, from our old pal Swervn
http://73-87.com/7387garage/drivetrain/tranny_hoses.htm
bigblock73 is offline   Reply With Quote
Old 07-18-2013, 05:53 AM   #13
a men a truck a dog
Thanks for the good info looks very neat. I'm a army vet so I love neat also. The question I still have is, without my 700r4 being modified with shift kit and other things, should I be worry about buying a cooler or will I be just fine running the lines right to the factory raidator ?
Old 07-18-2013, 09:01 AM   #14
Blackpony
Blackpony's Avatar
I would suggest going ahead and adding the second cooler if your budget allows. A nice setup with braided lines can be had for much less then the $250 you found if you just piece together it yourself. I think my setup cost around $180 and that was getting the largest cooler I could fine. It can only help control temps and especially if you pull or haul stuff it will make a big difference in the trans living a long life.
Blackpony is offline   Reply With Quote
Old 07-19-2013, 12:52 AM   #15
a men a truck a dog
Will do thanks again
Old 03-23-2016, 07:04 PM   #16
dirish
dirish's Avatar
I know this is old but.... $115.
Transmission cooling lines to radiator, using hydraulic
Lines.
dirish is offline   Reply With Quote
Old 03-24-2016, 09:37 AM   #17
jwilson645
What length and diameter hose did you use?
jwilson645 is offline   Reply With Quote
Old 03-24-2016, 10:18 AM   #18
dirish
dirish's Avatar
5/16 hose, I used 66", and 60". I would go 12" shorter, on each depending on routing next time. Imy happy with it though. Waiting
On radiator to get in then, I'll have a road test.
Old 03-24-2016, 10:33 AM   #19
esbstuff
I did hydo lines from the local shop several years ago and love them.
I however did not run them to the front, I ran them under the bed and mounted a self contained B&M cooler, fan and thermostat. Cool transmission fluid leads to longer life of the transmission. I believe (and I could be rusty) that builders recommend that transmission fluid stay at 120* for long life. Well if you are putting fluid in a 195* radiator, guess what?
esbstuff is offline   Reply With Quote
