Old 07-13-2013, 08:54 PM   #1
kswindell
Bed Diagram (Not the Wood)
My 61 is completely bare at the moment. Bed was junk when I picked it up so I never really got a great idea of how everything went together.
Does anyone have somewhat clear pictures of how everything goes together.
Specifically the front an back portions and where how the cross members go.
Thanks in advance.
kswindell is offline   Reply With Quote
Old 07-14-2013, 09:47 AM   #2
earl84
Re: Bed Diagram (Not the Wood)
kswindell, here are a few pics that show what you are after. I have several more, but these seemed to be the parts you are specifically after. Plus, I added a few extras.
earl84 is offline   Reply With Quote
Old 07-14-2013, 09:49 AM   #3
earl84
More...
Old 07-14-2013, 09:50 AM   #4
earl84
Last two, moderators, please edit if necessary.
Old 07-14-2013, 11:48 AM   #5
1963chev
1963chev's Avatar
Thanks Earl84, I needed that info as well!
1963chev is offline   Reply With Quote
Old 07-14-2013, 05:11 PM   #6
kswindell
My 61 only has the 4 Tall cross beams an then one thin that lays on the angle. Is that normal for that year or am i missing a piece all together?
Old 07-15-2013, 12:44 AM   #7
lasher78
lasher78's Avatar
i have a '66 stepper and my bed is bare just like that and i also ihave no idea how it all goes together. my question is how do you get those pieces that run down side off there are no bolts and then how do you put new ones on...im sure other first timers are wondering the same
live like you are dying
lasher78 is offline   Reply With Quote
Old 07-15-2013, 09:03 AM   #8
kieth
kieth's Avatar
Here is a link to my truck as we started to fit the bed wood, notice the grooves in the wood, the metal strips rest in those grooves and the bolts go thru the space between the boards and then attach to the metal crossmembers (thru the holes.
here is a picture:
http://kieth.smugmug.com/Trucks/66-G...Lzpm&lb=1&s=X2
Wood detail:
http://kieth.smugmug.com/Trucks/66-G...vCcFt&lb=1&s=A
Mar-k website for detail:
http://www.mar-k.com/Catalog/PDF/Ins...ood_Boards.pdf
kieth is offline   Reply With Quote
Old 07-15-2013, 09:17 AM   #9
earl84
Hmm, I don't know the answer to the kswindell, as this is the only 60-66 I have ever owned or seen in detail. Seems like you should have 1 more to me, but I can't say for sure.
And lasher78, sorry I can't help with that either.
A super productive post, I know
Old 07-15-2013, 01:21 PM   #10
lasher78
lasher78's Avatar
thanks to all
Old 07-16-2013, 09:54 AM   #11
kieth
kieth's Avatar
Originally Posted by lasher78 View Post
thanks to all
Here is some info on the wood itself.....
http://www.mar-k.com/Catalog/PDF/Ins...Dimensions.pdf
The wood at the front of the bed goes on top of the sheet metal angle .
the wood at the side of the bed goes on top of the crossmembers and under the angle (where the holes are )
the wood goes under the fenderwell
the wood at the rear of the bed sits on top of the sheet metal angle at the rear of the bed.
all pieces of the wood after they are cut to length and width sit approximately 1/2" apart (the steel strips dictate this and must have enough width to clear the carriage bolts that hold the steel strips down------washers hold the boards in place where they do not go through a crossmember...)
