Old 07-16-2013, 09:00 PM   #1
dwlambert1701
HEADER WRAP? Pros & Cons
Got a question for you all. Header wrap has anyone ever had it catch on fire. Mine did today I was ale to blow it out, but now I'm concerned. I've run my truck a good bite with no problems. but today when I shut it off it sounded like it was trying to backfire before the engine stop running. I had the hood rised and when I looked down I saw the header wrap near the oil filter on fire. Anyway just wanted to see if anyone else has had any bad experience with it themselves. Thanks
dwlambert1701 is offline   Reply With Quote
Old 07-16-2013, 09:10 PM   #2
kerber63
kerber63's Avatar
Re: HEADER WRAP? Pros & Cons
I've had a 350 and a 454 with wrapped headers, never had any issues. I am completely Pro for header wrap - it looks awesome and does a great job keeping the heat where it's supposed to be.
kerber63 is offline   Reply With Quote
Old 07-16-2013, 09:33 PM   #3
Psycho75
Psycho75's Avatar
I header wrapped mine and I think as long as you seal it with the high temp silicon spray so the flammables don't absorb into the wrap you will be good. At least that is what I am banking on. First fire up tomorrow.
"You can have it Fast, Safe or Cheap. Pick any two"
"If you're gonna be dumb, you better be tough"
1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617
1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552
Psycho75 is offline   Reply With Quote
Old 07-16-2013, 10:11 PM   #4
jayoldschool
Moderator
The main problem with header wrap on street vehicles is that it causes pipes to rust out.
jayoldschool is offline   Reply With Quote
Old 07-20-2013, 07:24 PM   #5
bama63
bama63's Avatar
x2 on that one.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-20-2013, 09:22 PM   #6
Vernski
Originally Posted by bama63 View Post
x2 on that one.
X3 looks to be allot of pro & con on this subject here is a link..Vernski
http://67-72chevytrucks.com/vboard/s...d.php?t=477864
Vernski is offline   Reply With Quote
Old 07-20-2013, 10:33 PM   #7
BigDan3131
BigDan3131's Avatar
They rust out from the moisture in the air plus any puddles you hit or car wash you go thru. I would only use them in a drag racing app.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-21-2013, 06:54 AM   #8
tincan1966
tincan1966's Avatar
Almost all header manufacturers will void any warranty if their headers are wrapped.
The most common mistake made is most do not install it correctly..
I agree that the wrap should be used for racing applications only.
tincan1966 is offline   Reply With Quote
