Old 07-16-2013, 09:42 PM   #1
Jfarns03
Jfarns03's Avatar
5.3L running original radiator. Will it work?
I was wondering if my original, leak free radiator will work with my engine swap? I have soon new stuff to mount to it!
A place for everything, everything in its place.
Check out my build thread!
http://67-72chevytrucks.com/vboard/s...43#post6129043
Jfarns03 is offline   Reply With Quote
Old 07-16-2013, 10:45 PM   #2
Thealien
Thealien's Avatar
Re: 5.3L running original radiator. Will it work?
I am using my stock 4 core in my 72 Jimmy for a few years now with zero problems. I am also only using a clutch fan.
Old 07-17-2013, 12:09 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
It depends on which radiator you have. There are two core, three core, and four core Radiators.
LockDoc
Leon
Old 07-17-2013, 12:13 AM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Even if it is leak free... doesn't mean it is free flowing. 40 year old original radiators can hold a lot of crud over the years. You might wanna take it to a shop and have it rodded out, or maybe even a recore.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-17-2013, 01:40 AM   #5
Jfarns03
Jfarns03's Avatar
how can i tell how many cores it has? thanks for the responses!
Old 07-17-2013, 07:38 AM   #6
MARKDTN
Look at it from the back side where it joins the tank and count the rows forward. You will see obvious rows of tubes.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-17-2013, 09:17 AM   #7
brad_man_72
the boat guy
brad_man_72's Avatar
I ran mine on a 2 core for years without any issues.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 07-17-2013, 09:25 AM   #8
67 chevelle
67 chevelle's Avatar
I think you will be fine , these ls engines seem to run cool , i hooked my steam line to the heater lines
im useing my stock radiator , still in build mode should be in run mode in a week or 2
67 chevelle is offline   Reply With Quote
Old 07-17-2013, 11:55 AM   #9
LockDoc
LockDoc's Avatar
Yeah, but he probably won't want to run beer in his cooling system...
LockDoc
Leon
Old 07-17-2013, 09:50 PM   #10
Jfarns03
Jfarns03's Avatar
Thanks guys I'm going to check tomorrow. I figure it's a two core because my truck originally came with an inline six
Old 07-17-2013, 10:25 PM   #11
Jon01
Jon01's Avatar
If it's a 6 truck it probably has the 2 row narrow core unit.
Either way, if it keeps the 6 cool you'll be fine. LS motors run very cool.
Jon01 is offline   Reply With Quote
Old 07-17-2013, 11:34 PM   #12
Ridgeclimber
I just installed a lq9 6 litre in my 1968 c10. I thought I would try the stock two core rad. I also am using Evans waterless coolant. I have a about 1000 km on it and no problems so far.
Ridgeclimber is offline   Reply With Quote
