06-11-2013, 06:50 PM | #51 |
Re: NP 205 Rebuild and Info
The 205 is one of the easiest things ive ever done on an r&r. I have done, nearing 15 of em id say, for people afraid of em. Its just parts. Same thing with a th400. Take it apart. See whats inside. Youd be amazed at the simplicity.
Posted via Mobile Device |
06-11-2013, 06:57 PM | #52 | |
Junk Yartist
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
06-11-2013, 11:41 PM | #53 |
Sounds good guys, thanks for the help
06-26-2013, 12:57 AM | #54 |
Junk Yartist
Wow. 2 years later...
Tips for the Yokes. I sleeved both. I use green lock-tite on them to prevent seepage between the parts. i apply RTV sealant to the inside of the yokes, and not the shaft. This way you will not be pushing RTV into the case. 10 spline front yoke repair sleeve part number (federal mogul 99174) 32 spline rear yoke repair sleeve part number (federal mogul 99212) Spline washer seal. important piece. Only works on the 32 spline yokes in my opinion. Torque for the rear yoke is 150lbft. repeat steps for the front yoke. The front has a dust shield. I will show pictures of the early style adapter for reference.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 Last edited by jbclassix; 07-01-2013 at 09:08 PM. |
07-04-2013, 07:32 PM | #55 |
PROJECT 7DEUCE
Do you happen to have any pics of the adapter seals? Mine is the o ring style on the trans to adaptor and idea on the case to adaptor seal? My trans was leaking atf into the t case so here I am..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-04-2013, 08:27 PM | #56 |
Auto Zone had mine in stock. They look just like wheel seals and the coupler just sits centered on them. They seal the outer part of the coupler while the inner is sealed by the "o" ring. Case to adapter gasket can be bought on ebay for a couple bucks.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-04-2013, 09:12 PM | #57 |
07-04-2013, 09:13 PM | #58 |
Those are the three seals you will need. Small oring is for the inside of the coupler. Big oring is for the trans to adapter. Regular lipped seal is outside of coupler.
07-04-2013, 10:29 PM | #59 |
PROJECT 7DEUCE
I found all the seals with the exception of the small o Ring seal to the shaft
07-04-2013, 10:56 PM | #60 |
Comes in my gm 205 gasket kits.
07-06-2013, 01:07 AM | #61 |
Junk Yartist
I have 2 lip seals in my adapter. The larger one obijuan doesnt have pictured i cannot find a PN for. For autos i recommend putting some silicone on the inside of the coupler like i did the yokes.
07-09-2013, 07:28 PM | #62 |
Junk Yartist
Here is what I have for seals.
there are 2 lip seals inside the 1st gen adapter. here are the 2 lip seals. transmission side transfer side here you can see where the 2 lip seals ride on the coupler here you can see the sealing surface the o-ring on the t-case input shaft seals against. Make sure this side of the coupler is on the t-case side. Also, clean the splines on the coupler, and put some silicone on it. This will act as a back-up to the o-ring.
07-16-2013, 06:35 PM | #63 |
Thanks for the added information, should come in handy....
07-20-2013, 11:43 PM | #64 |
Junk Yartist
Bad image of 32 spline front output shaft
07-21-2013, 04:31 PM | #65 |
Jbclassix. One helluva write up. When i tore mine apart it didn't have the spacer on the rear output. Now that i out it together the input from the tranny shaft slides back and forth. I've got it all torqued down but don't wantto put it in because when slid out it grinds horribly. When in farther it spins smooth as silk. Any ideas?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
07-21-2013, 04:54 PM | #66 | |
Junk Yartist
07-21-2013, 04:59 PM | #67 |
Yes the input from tranny. So the "slop" iis supposed to be there?
07-21-2013, 09:13 PM | #68 | |
Junk Yartist
07-21-2013, 09:19 PM | #69 |
I noteced it would move back on the sleeve. Could i just use a thick washer as a spacer?
07-21-2013, 10:01 PM | #70 |
Junk Yartist
You will actually need that spacer. The yoke, spacer, and gear keep the output shaft riding on the bearings where they are supposed to. but let me triple check that. I have an output assembly I need to rip into anyway.
07-30-2013, 12:19 AM | #71 |
Junk Yartist
Newer case with a staked idler shaft on the rear side to prevent rotation.
08-21-2013, 01:54 AM | #72 |
Killer write up Jeremy! Thanks for the read. After reading this thread, I was able to completely disassemble, clean and reseal the divorced dodge 205 that is replacing the old T221 in my '63. It came out great.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
08-21-2013, 11:20 AM | #73 |
63GENIII--does the dodge use the same mounting as the 221?
1961 chevy K10 my build is------------61K10 build |
08-22-2013, 03:03 AM | #74 |
Sent a PM. Didn't want to hijack but yes it fits
09-05-2013, 08:33 AM | #75 | |
