#126 |
Re: 496 to be DYNO'D!
Been waiting to se this beast in action.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#127 |
I haven't been out for about 3 years kinda took a break but hope to do some racing again this year. Was down to the Hat once before and liked the track, their LED lights not so much LOL, wasn't use to them.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#128 | |
![]() Posted via Mobile Device
#129 |
MOTORHEAD!
I hope to be able to hit Castrol in edmonton at least a couple times before the Hat... Just gotta get the darn money pit on the road...!
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
#130 |
Well if you are willing to go all the way to the Hat, may as well bring it to Saskatoon.
#131 |
MOTORHEAD!
I think we are planning a trip in August. Hows the back end of the track?
#132 |
Now has concrete.
#133 |
What dates are you planning to run in the Hat or Edmonton? If it works in my schedule I would like to take a trip to see your truck run. I'm thinking pretty hard about a 496 for my '81 shorty
#134 |
MOTORHEAD!
We had planned to do a pre-wedding drag race competition in the Hat on June 28th for my brothers wedding... However, he has cancelled that as he wouldn't want something to go wrong etc and put a damper on his big day... Unfortunately that kinda works for me as I have been unable to take time off work to get the truck completed... It is driving me nuts, believe me..... I'd hate to pay someone to finish what I have started, but that may happen... Best case scenario I am looking at mid July....
#135 |
.......Me likey!!!!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
#136 |
MOTORHEAD!
#137 |
Sounds like a big block should...Nasty.
#138 |
MOTORHEAD!
Ugh! I know! Still have right ear pain!!! Lol!
#139 |
So perfect then just like every engine I build...open header start up and 20 min run also for cam breakin, then ...say what
#140 |
MOTORHEAD!
Exactly!!! Didnt plan all the tools being shook off the work benches, but I guess that goes with havin a nasty bbc!
#141 |
Final part is when it still sounds Nasty with exhaust on it...then it really is and sure yours is by the sound of it.
#142 |
what made you choose the afr 265's over the 305's? im in a debate right now with myself on which to choose, i have a similar setup 496 @ 10.2, cam not chosen yet, but shooting for around 238/238 @ 050 with around .600 lift. i was leaning toward the 305's til i seen this thread, you made some good numbers with the 265's.
#143 |
MOTORHEAD!
Mark Jones, the builder at VortecPro, insists that the velocity of the air through the runners is the key. I told him what my plans for the truck were(85% street/15% track) , he told me what he would build for me. I'll easily run power brakes, and still be capable of decent track time... Which I can not wait to do!!!
#144 |
ya definitely velocity is key. i just thought 265cc on a 496 would fall on its faces in the 5k range, but your dyno says otherwise, i think i will go with the 265's. did you do any port work on the heads or was it straight bolt on from the box?
#145 |
MOTORHEAD!
Mark ported the heads. He says I can take it to 6500 if I so desire.
#146 |
Any idea what cc they were when they left his shop?
I assume he kept the stock valve? Any flow numbers? Posted via Mobile Device
#147 |
MOTORHEAD!
Yes he did use the stock valves. I believe from his post that 270cc was what he ended up with. Here are the flow numbers Mark provided.
Flow @ 28 inches, 4.310 bore. .200 171 .300 233 .400 281 .500 317 .550 323. 270 CC runner. Posted via Mobile Device
#148 |
Numbers are interesting. I would assume box stock the heads must have flowed less on his bench then AFR advertises? Even same pressure and bore, after the work, they show roughly 12cfm less on the average at every lift point except .200 where the show only 1cfm less.
Lift --- AFR --- Vortec .200 - 172 --- 171 .300 - 245 --- 233 .400 - 295 --- 281 .500 - 326 --- 317 .550 - 335 --- 328 Regardless of what the flow bench says, your motor makes good power and can't wait to see you bring in a 10 second time slip. Posted via Mobile Device
#149 |
i was going to say that same thing, the stock numbers show higher flow numbers, maybe its cause they are 80% cnc ported already?
#150 |
MOTORHEAD!
Hopefully see the track in August. There will be no slicks this year in the budget, but I do hope to run some half decent times on the sportsman s/r's.
