07-21-2013, 06:02 PM | #401 |
Rollin' Old Skool
Re: '63 GMC Project
Cool! So, are these the Mobsteel from Detroit Steel Wheel?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
07-21-2013, 10:42 PM | #402 |
Registered Loser
Re: '63 GMC Project
Yup.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
07-22-2013, 06:23 PM | #403 |
Re: '63 GMC Project
[QUOTE=creep;6183514]My 20" steelies showed up this weekend while I was away. Have to wait untill next weekend to test fit.
Posted via Mobile Device Posted via Mobile Device[/QUOTE/] They look great! I'm putting white ones on my 64. I'm kind of holding out because I k ow 22s are in the works. What are you doing for caps? Posted via Mobile Device |
07-22-2013, 07:02 PM | #404 |
Registered Loser
Re: '63 GMC Project
[quote=82swb;6185158]
07-26-2013, 03:33 PM | #405 |
Re: '63 GMC Project
Sick!!
63 big window lwb bagged and shaved |
07-26-2013, 11:00 PM | #406 |
Re: '63 GMC Project
some cool rides at the show!! thanx for sharing!! cant wait to see the new wheels mounted up
bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
10-11-2013, 04:47 PM | #407 |
Re: '63 GMC Project
R u running porterbuilt on it
10-29-2013, 05:54 PM | #408 |
Registered Loser
Re: '63 GMC Project
Not Porterbuilt but the same style system.
I still don't have the 20s on yet. I gotta change out my spindles and do some trimming in the front and get rid of the middle stake pocket in the back then HOPEFULLY they'll fit. Haven't been on in a while, been kind of a lousy summer for me, nothing major just lots of little crap. Can't complain to much with what other members are going through.
10-29-2013, 07:07 PM | #409 |
Rollin' Old Skool
Re: '63 GMC Project
How long did it take to get your wheels, & can you give me an idea of pricing? You can PM. I didn't notice anything on their website. Guess you have to contact them directly. I like these, but I also like the "Delmo specials" too.
11-01-2013, 12:10 AM | #410 |
Re: '63 GMC Project
What rear end did you chose
11-01-2013, 05:45 PM | #411 | |
Registered Loser
Re: '63 GMC Project
Not sure what your referring to but I am using a ************* rear suspension set up with what I think is a Chevelle axle redrilled to 5x5" bolt pattern. Apparently I can't tell you who's rear system I'm using even if I'm answering a question and not flat out advertising for them. That's whack.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. Last edited by creep; 11-01-2013 at 05:47 PM. Reason: censored post |
11-20-2013, 12:09 AM | #412 |
Re: '63 GMC Project
What size/width and backspacing on the 15's you were running?
11-20-2013, 12:22 AM | #413 |
Re: '63 GMC Project
I'm not sure what happened there I'm just trying to figure out how to easily swap a positrac rearend like chevell or camaro . Thanks for replying
11-22-2013, 01:27 PM | #414 |
Registered Loser
Re: '63 GMC Project
The 15s are stock wheels from a 92 C-1500. I believe they are 15" X 7" with 4" of backspacing.
11-22-2013, 01:35 PM | #415 |
Registered Loser
Re: '63 GMC Project
I had to weld brackets to my axle to mount the air ride setup anyway so I was able to use any rear end I could fit in it. The rear I used already had all of the stock mounting brackets cut off and smoothed out so I don't know how they line up but I doubt it's a simple bolt in swap. I also had to have my driveshaft modified to work with it.
11-23-2013, 12:09 PM | #416 |
Re: '63 GMC Project
truck is looking cool! Keep up the good work! T.J.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
11-23-2013, 02:26 PM | #417 |
A guy with a truck
Re: '63 GMC Project
Great build, even if you are using 'brand X' suspension The mobsteels are gonna look great. Also, kudos on the faux Hotwheels- that's too cool!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-26-2013, 05:21 PM | #418 |
Registered Loser
Re: '63 GMC Project
Nothing new with the 63 but I wrecked my daily S-10 2 months ago and the replacement truck I ordered came in this week. Just picked it up today... ...2014 Silverado LT
01-02-2014, 12:13 AM | #419 |
Re: '63 GMC Project
cool truck! i really like the new styling... cant wait to see those wheels on the 63, i was looking into a set for the 60 also!
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
01-29-2014, 10:56 PM | #420 |
Re: '63 GMC Project
01-31-2014, 10:39 AM | #421 |
Registered Loser
Re: '63 GMC Project
I made the Hot Wheels replica from 2 '62 Chevys and a GMC panel truck. The card is just a photoshop job I did on my computer. Here's a thread about how I did it.
http://67-72chevytrucks.com/vboard/s...d.php?t=509982 Here's the best pic of the one of the wheels during the test fit. Here's a vid of me starting the truck and pulling it into my storage unit. I shot this to see what the new horn sounded like from a distance. http://s9.photobucket.com/user/88ast...7ce9a.mp4.html
01-31-2014, 11:06 AM | #422 |
Rollin' Old Skool
Re: '63 GMC Project
The wheels are gonna look sweet. You gonna run a different center cap or sticking with those? The truck looks & sounds great in the video as well. I bet you can't wait to get it out of storage!
01-31-2014, 03:18 PM | #423 |
Registered Loser
Re: '63 GMC Project
Thanks. Yeah I wanna drive it so badly right now.
I am going to use the centercaps I have for now but I may evenyually get some smoothie centers for them.
02-03-2014, 06:58 AM | #424 |
Re: '63 GMC Project
Man your truck is amazing. Just read whole thread. Brand x looks like a great product I also like how the lca mounts. Would be nice to know the company. First time I've seen them block it like that. Wonder what the reason is. Which horn is that? I had a farmer buddy of mine give me a set of nathan air chimes they are crazy loud. One rule no kids and no grey hair for mine. I'd feel to bad if I killed someone with a horn
02-03-2014, 11:53 PM | #425 |
Re: '63 GMC Project
Good looking truck, my two kids heard it in the other room and came running and said "What was that!, it sounded COOOL!" Us three think its cool. Could I get some info on it and maybe a picture of it. Thanks.
