1985 GMC stepper 4 inch lift questions!
Hey yall, just trying to get all my ducks in older,I'm going to be running 33' MTZs, It's a 1985 GMC High Sierra short bed stepside 305 4x4, gearing is 3.08. Alright so im going to be being a 4 inch EZ Ride tuff country lift with blocks in the rear and a add a leaf too in the rear, maybe. I'm curious will i need to lengthen my drive shaft, or anything else?
1985 High Sierra step side 4x4
Re: 1985 GMC stepper 4 inch lift questions!
Done a couple 4" lifts & here's what I had to do: driveshaft should be fine,but mine were LWB trucks,changed to a raised pitman arm,brake lines were ok,but may depend on your application.The 3:08s might be too much for the 33s,but again depends on your wants& needs.If I missed anything,somebody will jump in...
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution"
33's, 305, 3:08's = a nice scenic ride!
my old K5 had a 4", didn't do nothing to the driveshafts, also used raised steering arm. |
I had a brain fart there! Was thinking about my 80 K10 with 4" lift.I ran 31s a long time with 2.73s,it worked good,but when I put 33s on it was too much.Went to 3:42s & that was way better! I did that lift really cheap,didn't even change the pitman arm either & it worked ok.Your 3:08s should be fine...
#5 | |
haha. and Alright thanks for the feed back!
#6 | |
| Bookmarks |
| Tags |
| gmc, lift, offroad, stepside, tuffcountry |
| Thread Tools | |
| Display Modes | |
