07-23-2013, 06:59 PM | #426 |
Re: 1968 Chevrolet SWB Stepside Restomod
Making some progress. Looks good
Posted via Mobile Device |
07-23-2013, 07:34 PM | #427 |
I fixed my bracket like yours. I like it. thanks Brian
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
07-24-2013, 05:29 PM | #428 |
Hey all;
The Camaro radiator and electric fan came in today. I test fitted the assembly and it fit fine, it looks like I don't have to move my engine. Even though the radiator is the right height for the stock mounting brackets to work they are in the wrong place so I will have to fabricate my own brackets. Onward and forward. |
07-24-2013, 07:44 PM | #429 | |
07-24-2013, 07:53 PM | #430 |
Good job there. I am glad that it works out for you.
07-24-2013, 07:58 PM | #431 |
Hey Brian,
Just spent the last hour reading your build, looks great. Your gonna love that ls, 17 mpg, overdrive transmission, no cold starts and plently of power. My only problem is keeping the my foot out of it. I've already been selling all my old small block parts, I've got my truck tore back apart for new body and paint seems like its taking forever. Did your do your own harness or purchase? Keep up the great work. Dave Posted via Mobile Device
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
07-24-2013, 08:28 PM | #432 |
Hey Dave thanks for stopping by and for the kind words.
You should put a link to your build thread in your signature. I purchased a Standalone Wiring Harness from (PSI) Performance Systems Intergration. |
07-24-2013, 09:04 PM | #433 |
I think I will put a link in, I tried to start a build thread on lsx swap side but no one put it up on the site.
Ive heard good things about the psi harnesses, I did my own using info from members here. It took a lot of time and cussing but I did learn a lot about the engine,transmission, sensors,etc. I also used the fbody radiator and fans, they work and fit great. Dave Posted via Mobile Device
07-24-2013, 09:31 PM | #434 |
Hey all;
I just purchased a heater delete hose so I can drive the truck while I'm saving up for the Vintage Air system, here's a link incase you are interested in purchasing one. http://www.ebay.com/itm/160884055553...84.m1439.l2649 |
07-25-2013, 05:22 PM | #435 |
Hey, Brian I bought the stock column you sent me the link for. So it want be to long that I can see a big change with the old girl. A few more parts came in today. A new HEI distributor, a new 3'' chrome air cleaner, a new set of 350 emblins for the fenders and a power steering pump. It leaked in transit so I have to clean it up.
You should have said something about the hose. I would have gave you one. But now you can get the beast running.
07-25-2013, 08:02 PM | #436 |
Hey all;
Today I went and purchased some 5/16 to 3/8 adapters for the radiator and some 3/8" compression fittings so I can rerout the transmission cooler lines. Whenever it stops raining I can get the cooler lines installed. |
07-25-2013, 08:26 PM | #437 | |
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
07-26-2013, 05:46 PM | #438 |
Hey all;
Today I bent and installed the Transmission cooler lines, I might have made the lower line 1" too short so I may have to redo that one. Last edited by Xeen; 07-26-2013 at 05:52 PM. |
07-26-2013, 07:38 PM | #439 |
It looks good from here. I can't see the difference between the two.
07-26-2013, 08:01 PM | #440 |
Good job on the transmission lines. More notes taken
07-27-2013, 05:07 PM | #441 |
Hey you need to spend some time on that rear end housing. It makes your work look undone. A wire wheel and some primer and paint. And a lot of elbo grease.
07-27-2013, 05:20 PM | #442 | |
Luckily it's not greasy it just needs the old paint stripped off and repainted. |
07-28-2013, 02:44 PM | #443 |
yea I can relate to the heat. in the 90's here. That is why I buy parts and don't get to install them.
07-30-2013, 07:21 PM | #444 |
Hey all;
I have been wrestling with the idea of moving my engine back 2" towards the firewall for some time now. Recently CPP released a new redesigned sheetmetal engine perch that is more like the original factory perches and give a lot more clearance for exhaust manifolds and headers. After learning about the new perches I decided to go with them instead of the tubular perches and move my engine back at the same time that I change them out. For all you guys who are curious here is a stock CPP photo of the new sheetmetal perches with Hooker GM clone manifolds. |
07-30-2013, 09:02 PM | #445 |
I was about to say man that don't look like your truck. I thought you had headers and then I read what you posted. Good luck with the switch and the moving to the rear.
07-31-2013, 03:24 PM | #446 |
I got your drive shaft all sand blasted and primed and painted. I sent you a PM this afternoon. About the front yoke.
07-31-2013, 05:59 PM | #447 |
07-31-2013, 08:54 PM | #448 |
Looks good buddy!
08-02-2013, 08:09 PM | #449 |
Did you get the motor slid back thoes 2 or 3 inches and the transmission lines also.
08-02-2013, 09:11 PM | #450 |
I'm waiting for the new perches to be delivered.
Tags |
1968, chevrolet, restomod, stepside, swb |
