Old 07-23-2013, 09:52 PM   #1
JCampbell
'90 454 No Crank
'90 C30, TBI 454 - No Crank
Over the last two days, I noticed an intermittent "chatter" of the starter when starting the engine after it's been running/warm (ie: after getting gas, etc). Today, after stopping to get fuel, no crank. Towed truck home, pulled starter, bench test: starter passed.
Reinstalled starter. Cleaned connections @ starter and battery, reconnected and attempted to crank engine. Nothing on first turn of key. Single, brief "click" on second turn of key, but no crank. Nothing on third, fourth, fifth turns of key.
Verified power @ starter w/ test light. Had assistant hold key in "crank" position while I checked for crank signal w/ test light. No crank signal; however, heard a "pop" and brief sizzle while checking for crank signal-possibly blew a fusable link holding key in "crank" position too long???
Any thoughts?
JCampbell is offline   Reply With Quote
Old 07-23-2013, 10:16 PM   #2
mrolds88
Re: '90 454 No Crank
Might be the switch on the column. I know its a pain to change, but if you can get the connectors off, the either jump the starter posts or if you have a spare one to ttry on there. Just a thought. I had one years ago that, because I was so broke ( how brojke was I??) I couldn't pay attention!
I actuall stripped the switch down, cleaned the junk out and polished the terminals with a ink eraser. Put it back in and worked perfectly for the years I owned it.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 07-23-2013, 10:24 PM   #3
manimal
manimal's Avatar
Sounds like a fusible link. can you cross start it?
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 07-23-2013, 10:32 PM   #4
manimal
manimal's Avatar
do you have lights?
-Lance
Old 07-23-2013, 11:30 PM   #5
JCampbell
Yes, I have lights.
Old 07-23-2013, 11:34 PM   #6
rs74
rs74's Avatar
My daughters boyfriend had a similar problem on his 94 K1500. It ended up being corroded battery cables. Replaced them and everything has been find since. He had lights and everything. Sometimes it would start and other times not.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-23-2013, 11:49 PM   #7
JCampbell
Que?
Old 07-24-2013, 01:11 AM   #8
manimal
manimal's Avatar
with a screwdriver across the terminals on the starter?
-Lance
Old 07-24-2013, 10:27 AM   #9
D.FENS
Had a similar problem on my truck. Turned out both the starter trigger and main power wires were corroded inside.
Both wires would light up a test light, but wouldn't flow enough current to spin the starter.
D.FENS is offline   Reply With Quote
Old 07-24-2013, 05:00 PM   #10
manimal
manimal's Avatar
Well?
-Lance
Old 07-24-2013, 05:03 PM   #11
manimal
manimal's Avatar
The trigger wire for the starter should be purple if I remember right. Look for it on the main harness block on the fire wall and test it there. If you have power when key is in the "start" position, it is broken down stream. If you dont have power there,check the ignition switch on the column.
-Lance
Old 07-24-2013, 06:47 PM   #12
JCampbell
Yeah, I think the crank signal wire grounded out or is broken somewhere. The "pop" I heard when I was testing for crank signal was the fusible link blowing. Replaced the link this afternoon, and decided to test for crank signal a little further "upstream". Grabbed a hold of the harness near the alt to pierce the crank signal wire and the truck fired. Must've moved it enough to restore continuity.
Still need to replace the signal wire, but at least I know what the issue is now.
