Old 07-25-2013, 09:45 AM   #1
ckato4477
shortbed grafted onto blazer tub idea
So, i think blazers look a little goofy with the shorter wheelbase when lifted with bigger tires. My solution is to graft a shortbed onto the blazer tub for about 6" more wheelbase.
My question is how different the bed mounts on a shortbed frame are from the "bed" part of the blazer are. I'm having trouble finding frame dimensions for a shortbed frame.
ckato4477 is offline   Reply With Quote
Old 07-25-2013, 11:20 AM   #2
70-K5
Re: shortbed grafted onto blazer tub idea
That's a lot of work cutting the frame in half and adding 6", then adding sheetmetal to the bed too.
Instead why don't you get a windshield frame from a K5 and cut the cab off a short bed pickup then fill the seam between the bed and the cab. That's just as crazy an idea but either way you're going to be doing a wholey ton or work!
70-K5 is offline   Reply With Quote
Old 07-25-2013, 11:22 AM   #3
fast eddie1968
I had thought about doing this !If you do it take lots of picks please.
fast eddie1968 is offline   Reply With Quote
Old 07-25-2013, 01:25 PM   #4
ckato4477
I disagree, the frame work would litterally take me about an hour and a half if all it took was chopping the frame before the front spring perch and adding 6". I already have the frame stripped and i'm getting ready to box it. Adding the 6" wouldn't be a problem.
the question was pertaining to the body mounts and bed mounts....are they the same or not? if not, then where do i need to stretch the frame?
Old 08-05-2013, 10:13 PM   #5
ckato4477
well i got started, heres a couple pics. check out my build thread if you want to see this one through all the way:
Old 08-06-2013, 11:15 AM   #6
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Go for it.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 08-06-2013, 11:44 AM   #7
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
subscribed and watching, you may be on to something here
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-06-2013, 03:30 PM   #8
ckato4477
Here's a link to my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=589951
