07-26-2013, 08:29 PM | #1 |
Hood/cowl hinge pads
Does anyone know where to get these rubber/foam pads located at the bottom of the hinges on the cowl? Also, what is the foam pad between the fender and the cowl in the second pic? Is this part available also? GM part numbers would help. It looks like the part numbers have been superceded more than once. Thanks.
07-27-2013, 06:37 PM | #2 |
Re: Hood/cowl hinge pads
i want to know where i can get the rubber pieces for the hinges too !
**BUMP**
1986 LWB c10 w/327 & vortec heads |
07-27-2013, 09:00 PM | #3 |
Cruzzzn' Vet
LMC carries them
07-28-2013, 12:06 AM | #4 |
Can you tell me the LMC part number? I don't see them in the catalog. Thanks.
07-28-2013, 12:59 AM | #5 |
OK. I see the parts in the online catalog now. They were not in my latest paper catalog from LMC.
Does anybody know about that foam cushion between the fender and the A pillar/cowl area? Is it an anti-squeak device or is it a water seal? This is the second pic in my original post. Thanks. |
01-07-2014, 10:09 PM | #6 |
part number? I dont see it.
Also there was a rubber pad about an inch thick and 3 inches long glued on the bottom of the cowl on both sides. I dont see that anywhere. I cant wrap my brain around your picture. can you take one from farther away. |
01-08-2014, 05:32 AM | #7 |
that foam is there to absorb water and cause a nice rust spot, most GM cars have them in and around the a pillars. I always remove those. Sure they are probably for some kind of noise or rattle issue but I'd rather have a rattle then rust
01-08-2014, 02:53 PM | #8 |
did anyone else have trouble putting these pack on? Seems i stripped on side on mine like the screw holes got pulled up
Rust is better than rice. |
01-09-2014, 12:35 PM | #9 |
78K & 79C Jimmys
I think your looking at this...was my 87
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
01-09-2014, 01:55 PM | #10 |
Don't Crush em Restore em
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
01-09-2014, 03:36 PM | #11 |
Yes, #6 in that catalog listing
