Old 07-27-2013, 07:03 PM   #1
rs74
rs74's Avatar
Rockwell or 205 transfercase?
I know the Rockwell's come out factory in these trucks but just wondering if they are any better than the NP205's. Is there any advantage as to having the divorced Rockwell. It seems from what I have read that when the rockwell TC is not is a truck of this vintage that they are disappointed. Any reason for that other than that is what they come out with. Seems like they are harder to find too. More curious than anything.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 07-28-2013, 08:42 PM   #2
rs74
rs74's Avatar
Re: Rockwell or 205 transfercase?
Roy
1987 R10 shortie
Old 07-28-2013, 08:43 PM   #3
ky-donzi
I prefer 205... Bullet proof, can be had in married or divorced, and plenty of parts...... 221 parts are are to find
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 07-28-2013, 09:47 PM   #4
'63GENIII
'63GENIII's Avatar
My Rockwell is starting to make more noise than before. I know its just a matt,er of time before it blows up. I'm going to swap in a divorced 205 instead of rebuilding the Rock. I like to the fact that it still has the original t-case but the 205 is just quieter and stronger.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-28-2013, 09:53 PM   #5
rs74
rs74's Avatar
What is the reason some are divorced and the others not? The divorced TC thing is kind of new to me and I am trying to understand why they were built that way. Was it just the way they did things back then since all of the trucks that are newer are all married applications. Does the divorced give any benefits?
Roy
1987 R10 shortie
Old 07-28-2013, 09:59 PM   #6
jtrichard
you can generally lift a truck more with a divorced case ....front shaft is longer
jtrichard is offline   Reply With Quote
Old 07-28-2013, 10:07 PM   #7
ky-donzi
My guess is that in the early year of 4x4 it was easier to source the transfer case and transmissions from vendors as divorced.
Old 07-28-2013, 10:08 PM   #8
'63GENIII
'63GENIII's Avatar
Agreed. Less drastic drive line angles. Greater versatility to change transmission type if you're like me and change your mind on occasion.
Chris
'63 k15 long step
Old 07-29-2013, 12:43 PM   #9
61K10
61K10's Avatar
what years are the 205 divorced tc
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-29-2013, 12:53 PM   #10
ky-donzi
Depends on the manufacture, ford, international, and dodge used divorced later than GM. Ford will be driver side drop (think ford high boys) last year 73ish. The rest will be pass side drop... Seems like international never used married in there pickups. Idk bout Dodge ... Sometime in the mid 70's prolly
Old 07-31-2013, 01:35 PM   #11
61K10
61K10's Avatar
A few more questions--are the 205 divorced a direct bolt in when replacing the RW 221? cross-member the same? D/shafts?
1961 chevy K10
Old 07-31-2013, 01:53 PM   #12
padresag
no; but it is not that hard. it is advisable to get the mounting brackets from what it comes out of. mine came out of a 72 scout. the dodge 205 is also a r/hand drop but has oddball flanges on it. you can take the parts from a ford 205 and put them into a r/side drop case and I believe that you can use the married 205 case. fed-mogul trans o/haul kit for a 205; kit nbr T-172 (ihc # 412122c91 for 205 w/3.1496 o/d input brg
the noisy t221 above can more than likely be tuned up with new brgs.,shims and seal. they are not the quietist of t/cs to start with. I do have some t221 parts inc the aluminum end caps
ron
I could more than likely take some pics for you as to how mine is mounted
padresag is offline   Reply With Quote
Old 08-01-2013, 12:00 PM   #13
maxwoof
The upper input bearings are often the first to go on the t221. Usually because the oil level gets low at some point. I changed the rear upper in mine with the case in the truck. Fairly easy to do. Might be able do the front in the truck as well. Also was able to replace all seals while in the truck, and found that removing bearing retainers and shims, cleaning and reinstalling with permatex eliminates most leaks.
maxwoof is offline   Reply With Quote
