Old 07-27-2013, 09:47 PM   #26
Stepside Man
Stepside Man's Avatar
Re: 78 heavy half ton
Sure it will. With less support of the curvature of the leaves below it, the main leaf will flatten out, causing more drop.
It can also increase axle wrap and lowering the load capacity too. You just have to decide which of these factors matters....and how much.
This is somewhat true when you put a substantial load in the truck. Keep in mind you are not removing all the helpers, just two. this gives you almost the same pack set up as a 1/2 ton. The truck's main leaf will not flatten out.
I have done this. I have three sets of heavy half springs. The reduced pack acted like the set on my 78 C10 Stepside. It is true that the front springs will be mismatched.
1977 K10 6ft Stepside L6
1978 C10 8ft Stepside 400
1980 C10 8ft Widebox with Uncle L6
1986 K35 Not a dually 350; 79 K20 Stripped
1973 and 1976 Chevy Truck Trailers
1995 Impala SS LT1
Stepside Man is offline   Reply With Quote
Old 07-27-2013, 10:01 PM   #27
88Jimmy4x4
88Jimmy4x4's Avatar
I need to remove some leafs on my 56" heavy half leafs too
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 12-31-2013, 11:03 AM   #28
Old School Low
Old School Low's Avatar
1/2 came w 1,475 or 1,550 coils. HH 1,625 or 1,700 (GM info)
OLD SCHOOL LOW: 78 Short Wide Heavy Half-Ratty Rod at moment. Old 4blt stroked to 383
Vortecs, Weiand, Scat, Hedman 1 5/8, Howards Roller, .495/500, Scorpion.
Leaf flip, cut coils. Make do tires and wheels for now. Slip ahead a year? Sold GMC, bought Harley, got all obsessed doing the biker thing, now starting again w 65 SWB, 283,2bbl, 3 on tree.
Old School Low is offline   Reply With Quote
Old 02-18-2014, 10:18 AM   #29
Straight six
Straight six's Avatar
So I know I have the 1.25 front brake rotors which means heavy duty.. Well what calipers do I buy 1/2 ton or 3/4 ton calipers. I heard the 1/2 and 3/4 are the same calipers just different rotor size..
1978 GMC C15 4.1 250
Twitter: StraightSix78
Instagram: StraightSix78
Straight six is offline   Reply With Quote
Old 02-18-2014, 11:48 AM   #30
Old School Low
What did u mean by, front springs will be mis matched?
Old 02-18-2014, 11:53 AM   #31
Old School Low
Hey straight six. I talk a lot but dont get a lot done. But today...seriously considering removing leafs from my 78 Heavy half or even flipping. Id love to get rid of the thickest bottom leaf then 2 more, (every other one) before I flip and see if low enough. Hope you keep posting how you;re coming along.
Old 02-18-2014, 12:08 PM   #32
Straight six
So I guess nothing on my question about what front calipers to use on 1.25 hd front rotors
Old 02-18-2014, 12:31 PM   #33
Old School Low
Here you go: LMC Truck Parts (must have catalog) pg 175, pn 34-3912-Z is caliper set for 73-78 1/2 AND 3/4 ton 2wd. $49.95ea w $30 core chg
Old 02-18-2014, 12:37 PM   #34
Straight six
Awesome thanks.. And I just bought a new 56" 1950lb 7/1 leafs for rear I don't want to move the hangers.. I'm gonna put the mcgaughys drop coils in front should be fine...
Old 02-18-2014, 12:48 PM   #35
Old School Low
Yeah, moving hangers would be LAST option.. I have 7/1 (7 w THICK bottom helper, right?), but want to remove 3 of them to see if low enough w extended shackle I put on this week. And I saw somewhere, today I think, how much coil to cut on these hd front coils. Did u see it, what did it say?
Old 02-18-2014, 03:23 PM   #36
karl
karl's Avatar
They also have a heavier rating so you pay more to license them (at least here in Calif). I have a 77 heavy half. The smog devices are the same as 3/4 ton also. For 77 no cat and no EGR.
karl is offline   Reply With Quote
