07-28-2013, 07:09 PM | #1 |
Installing a new fuel filter
OK. So I want an extra fuel filter upstream of the fuel pump. Would it be OK to loop rubber fuel line hose where the metal fuel line hose ends, insert the filter canister there, tie it off to one of the heater core hoses, then attach it to the fuel pump? What say you guys?
Right now, the fuel filter is located inside the carb and I want one upstream of the pump. Now that I have everything unhooked so I can blow out the metal fuel line and replace all the rubber hose, it seems like a great time to put in an extra filter. Posted via Mobile Device Last edited by In The Ten Ring; 07-28-2013 at 07:20 PM. Reason: accidentally hit return |
07-28-2013, 07:46 PM | #2 |
Re: Installing a new fuel filter
I installed a fuel filter at the rubber hose under the cab near the fuel tank and has been working great for many years
Fuzzy |
07-28-2013, 07:47 PM | #3 |
a length of rubber fuel line longer than a couple of inches is a great way to burn your truck to the ground
07-29-2013, 01:09 AM | #4 |
20' Daredevil (Ret)
That's where mine has been for over 36 years -- no problems.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-29-2013, 06:51 AM | #5 |
1969 Custom 30 wrecker
I always put one in the rubber hose that goes into the fuel pump. Never had a problem doing it this way.
I use either the metal can type or the plastic Fram type. NEVER use those crappy glass ones. That's a sure way to burn your truck to the ground!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
07-29-2013, 07:40 AM | #6 |
don't tie it to a heater hose unless you want to boil the fuel out of the line
1970 short step c10 leaf spring 454 |
07-29-2013, 09:23 AM | #7 | |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-29-2013, 12:26 PM | #8 |
No glass ones? Check! Won't do that.
I thought about putting one under the cab, between the two lengths of metal fuel line that are there but that seems hard to get to for checking.... I only have about 6 inches of rubber hose that goes into the fuel pump....and that's hard to reach for me (behinding over the engine bay).... Could I put in a longer length of rubber hose going into the fuel pump and say, tie it to the heater hose by a length of rope? I'll take your advice and not tie it directly to the heater hose! Thanks. |
