Old 07-31-2013, 06:20 PM   #26
chevylover2013
chevylover2013's Avatar
Re: Starting with no key?
Originally Posted by Skunksmash View Post
My old 81 used to not need a key to start. LOL
Imagine my surprise when one day, I was walking in front of my 87 and it... wait for it...
Starts up and runs all by itself with no one in the thing! Needless to say I got to the root of that problem real damn quick.
LMAO!!Christine!!!
Help!!!! My Chevy has a Ford stuck in it's intake manifold!
chevylover2013 is offline   Reply With Quote
Old 08-01-2013, 03:54 PM   #27
nheller76
nheller76's Avatar
Ok so ive got the starting without the key thing figured out now were is the neutral safety switch because i cant get it to start at all now!
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 08-01-2013, 09:49 PM   #28
nheller76
nheller76's Avatar
So anyone got anything on this?
Old 08-01-2013, 10:32 PM   #29
wilkin250r
wilkin250r's Avatar
We want to know what the problem was!
The neutral safety switch is part of an apparatus that is attached to the lower portion of your steering column, right about dead center between the pedals, and it should also house the reverse light switch.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 08-01-2013, 10:54 PM   #30
nheller76
nheller76's Avatar
Thank u! So the issue was the wires, I think! Also there was a ground that was not hooked up. So does anyone have a pic the the switch
Old 08-02-2013, 12:26 PM   #31
nheller76
nheller76's Avatar
Ok so now that's not the problem I hooked the NSS up to the switch on my shifter and still nothing. I cut the wires and crimped new ends on them and hooked them up? did i do this right. So anybody got any other ideas?
Old 08-02-2013, 01:12 PM   #32
nheller76
nheller76's Avatar
I left the wires to the ignition switch plugged in and when I turn the key to the 2nd position there is power to the truck. I know the starter works because I have a test button and it is making it work.
Old 08-02-2013, 06:37 PM   #33
chevylover2013
Wish I could help! This is the scariest part of my build right here. When it comes time to re-wire the truck and things all of the sudden won't work.
Wish you luck. Keeping my eye out for your solution on this one for future reference.
Old 08-02-2013, 07:03 PM   #34
LynnJr
Glad to see you are getting it sorted out.
On the wiring of the neutral safety switch bypass it for now by tying the two wires together and see if it starts.This will take away the silly stuff like you don't have the transmission linkage adjusted correctly and that is keeping the switch in a position that won't let it start.
If it doesn't start and the truck has power follow the power you have and see were it stops.It sounds like you have a broken wire somewhere.If you have a friend handy make them hold the key fully on while you get on the floor of the truck and jiggle the wires from the ignition switch and the harness all the way to the firewall.
You can then try the same thing under the hood just make sure you tell your helper to let go if it tries to start.
If that works replace those wires with more crimp on wires.
LynnJr is offline   Reply With Quote
Old 08-02-2013, 11:16 PM   #35
nheller76
nheller76's Avatar
Good news I figured it out! So I have a new NSS and back up light switch on my new shifter so I did that and I still wasn't getting any thing. I then started from the beginning with my wires and low and behold the ignition wire that I had to replace had come apart from the crimped end that I pluged into the fuse box! So I redid it and like a big blue monster she worked!!!! Thank I all for your help!
Old 08-03-2013, 12:49 AM   #36
chevylover2013
SWEEEEEEEEEEEEEEEEEET!
Wiring is the scariest part of my rebuild! I am reading every wire trouble shooting thread I can to prepare for latter.
Old 08-03-2013, 01:51 AM   #37
INSIDIOUS '86
INSIDIOUS '86's Avatar
Do you have an alarm system? Is the wire getting power at all time? The only time the sylinoid wire should get power is when it is turned on with the key.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-03-2013, 04:46 AM   #38
nheller76
nheller76's Avatar
Yea I think I had few things going on;
1- my starter was bad
2- my 36 year old ignition wire and accessory wire just pooped out on my
3- I am switching to a floor shifter and pulled out my colum shifter and didn't get my NSS in order
4- when I redid my ignition wire I just did a crappy job the first time and the wire pulled out of the crimped end and wasn't getting any signal to the starter to start
