Old 07-31-2013, 08:17 PM   #1
daveboy
daveboy's Avatar
wiring up turn-signals
I know there are several threads here about wiring up turn-signals and I have read most, if not all of them. Here is where I need help: My '52 came wired for turn signals and the switch is mounted on the column. Problem is that there is no flasher. It is a 7-wire switch. I find where the two wires have terminals on them to plug into the flasher, and I bought a 3-prong, 6V flasher (still running original 6V system). I cannot find a third wire with a terminal in the same location, so am guessing that I will have to wire the flasher into power. The three prongs on the flasher are marked, "P, L and X". Which prongs go to the terminals to the switch and which one goes to power?
Thanks,
daveboy
daveboy is offline   Reply With Quote
Old 07-31-2013, 10:34 PM   #2
Wrenchbender Ret
Re: wiring up turn-signals
The P is wired to the ign. switch or fuse block so it is hot when the switch is on. The L goes to the turn switch & the X is for an indicator bulb.
Wrenchbender Ret is offline   Reply With Quote
Old 08-01-2013, 07:54 AM   #3
1project2many
Yes... you don't need to connect anything to the X terminal if you don't have an indicator
1project2many is offline   Reply With Quote
