Old 07-31-2013, 10:00 PM   #1
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
69-72 horn button assy?
Cr*p...
HOW. Do these parts go together correctly. I get No movement (of the silver metal cup)with the screws tightened down. The contact ring is behind it and the cupped end is facing out towards the driver.
Tom Vogel is offline   Reply With Quote
Old 07-31-2013, 10:42 PM   #2
Mister-B
Re: 69-72 horn button assy?
Originally Posted by Tom Vogel View Post
Cr*p...
Make sure the metal disc that's at the bottom, has the raised part facing up so that it'll click when pressed. Spin it around to different areas to line up the holes. When installing the plastic parts and screws, make sure they fit well, and tighten down each screw a bit, going from screw to screw until tight but not TOO tight
Mister-B is offline   Reply With Quote
Old 07-31-2013, 10:42 PM   #3
franken
The round, sort of disk shaped spring goes in like an upside down bowl, then the metal cup, then the plastic ring with the insulators the screws go through. I think...
I'd guess you have the disk upside down.
I mocked up the parts from my horn junk pile in a wheel and it feels right.
I can snap a pic but too big to post.
Old 07-31-2013, 10:46 PM   #4
Mister-B
Like this
Old 08-01-2013, 01:31 AM   #5
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Well... That's exactly the way I have it. Hmmm... I can't push mine in at all. I have a pic but for some reason the board is not letting me upload it. It looks just like Mister-B's pic.
Old 08-01-2013, 01:53 AM   #6
Mister-B
Loosen the screws a little, take a very small screwdriver, and slide the edge of the bottom plate in place to make sure it isn't pinched somewhere. You have to get it just right, or it'll be pinched and won't work
Old 08-01-2013, 08:54 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
My bottom plate is an aftermarket repop. There seems to be alot of cup to it. Wondering if someone has a decent original theyd sell.
Old 08-01-2013, 04:28 PM   #8
camrycurt
camrycurt's Avatar
Are you talking about the plate underneath the cup that flexes back and forth? If so, I have one that I'll send to you. It's a little rusty underneath but you can try it. It came in a parts lot that I got so I've never used it or installed it - it's factory so I assume it will work but you're welcome to give it a shot.
Give me your address and I'll send it to you.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 08-01-2013, 06:15 PM   #9
Tinsmith9
Tom, I think the info you got here is right. I just got mine to work for the 1st time this past week. The problem with mine was the rust in the bottom of the steering wheel wasn't allowing a good connection with the cupped contact ring. Like Mr-B said, just back the three screws off a little bit and you'll probably get the assembly to rock back and forth a bit. Good Luck!
Dan
Tinsmith9 is offline   Reply With Quote
Old 08-30-2013, 10:10 PM   #10
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Tom, Funny - I'm dealing with the same issue - for a year. Gotta figure this out. What was your solution?
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 08-31-2013, 09:52 AM   #11
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
That was apparently the problem. Works fine now.
