08-01-2013, 03:54 PM | #1 |
No spin?
On my glove box door the sticker has this listed:
G86 No Spin rear axle. My question, does this mean limited slip? There is definitely nothing external to lock the diff, Its an Eaton HO72
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
08-01-2013, 07:36 PM | #2 |
Re: No spin?
It means what it says. Like a limited slip, the no-slip or no-spin, works automatically- there is no external lever or button that needs to be engaged. It is the fore-runner to the Detroit Locker. Jack it up on the pumpkin and put it in neutural, NOT RUNNING, then rotate the tire forwards or backwards and if the opposite side turns in the same direction it is a no-spin. If it rotates opposite, it is an open diff.
I have a '70 GMC parts truck that was factory 4.57 and no spin (Dana 60) but when I pulled the cover off I found 3.73 open. So you never know exactly what your getting with an old vehicle.
08-01-2013, 08:23 PM | #3 | |
Re: No spin?
08-01-2013, 08:47 PM | #4 |
Re: No spin?
Like has been said it is a locking differential unit that replaced the spider gears inside the differential case. What makes you think your truck has a HO72? HO52 axles were stock for CK20 trucks.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-01-2013 at 09:05 PM. |
08-01-2013, 11:13 PM | #5 |
Re: No spin?
Keep in mind this is a uncertain guess gathered from what i have been researching on different forums and i have yet to prove anything out.
The HO72 and HO52 are mainly different by weight designation, and brake size, yet i cant find anything for sure on the brake size. But HO52 i think is rated at 5200 and the HO72 at 7200lb Some of other stuff other "experts" say like the HO52 only has 2 spider gears Vs 4 for the HO72 dosent seem to pan out ether. If you or anybody have any info or leads (even better a casting or stamping numbers chart) it would be greatly appreciated.
08-02-2013, 12:05 AM | #6 |
Re: No spin?
Been doing a lot of research, unless you think the axle has been changed it is probably the factory K20 HO52 (5200lb) axle. The brakes would be 11 x 2 3/4". There was also a Dana 60 (5500lb) usage in the K20s but that is very different looking intergral carrier style axle.
A C30 rear axle, HO72 (7200lb) has a heavier housing and 13 x 2 1/2" brakes on SRW trucks. Often people cite the load bolt that controls ring gear deflection as an indicator but it isn't. Fact is the drop outs are interchangable with the difference being the housing itself, the bearings, hubs and seals are the same. At this point the easiest thing to do is check the axle code and see if it is a K20 or a C30 application. There is no code overlap I know of between the two. But the catch is the carriers are code stamped and not the housings. There is an axle code chart in the parts manual.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 08-02-2013 at 12:15 AM. |
08-02-2013, 01:47 AM | #7 | |
Re: No spin?
Posted via Mobile Device |
08-19-2013, 05:23 PM | #8 |
Re: No spin?
Would it be safe to say I have the ho-72? There is an adjusting screw on the driver side of the diff plus my rear drums are pretty big, my rims are 16.5 and my drums look to be about 3" smaller plus they have the heat dissipation ribs around the outside. I need to get under it and find some numbers soon. I can't upload pictures now
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
08-19-2013, 07:01 PM | #9 |
Re: No spin?
11 x 2 3/4" C20
13 x 2 1/2" C30 Like I said earlier the load bolt is not a positive tell. The only way to know anything is to decode the drop out. The axle housing would have to be a judgement call based on original installation and brakes. Why are you wanting this to be a HO72 anyway? The 13" drums are about impossible to find.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-19-2013, 07:24 PM | #10 |
20' Daredevil (Ret)
Re: No spin?
Correct me if I'm wrong.... HO72 always has the load bolt, HO52 some have it and some do not. My K20 has an HO52 with the load bolt, and FWIW the drums are finned.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
08-19-2013, 08:03 PM | #11 |
Re: No spin?
That seems to be the pattern at this point. If you have a load bolt rear, post up the axle code stamped into it.
08-19-2013, 08:08 PM | #12 |
Proprietor of Dale's Corner
Re: No spin?
My drums are finned also.. now for the stupid question what is a load bolt?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-19-2013, 08:49 PM | #13 | |
Re: No spin?
Yea i know 14 bolts are plentiful, I've thought about it a lot, i just want to go this route for now, i figure if i ever decide to convert to 14 bolt i can use the disk setup when i cross over as well if i cant find a 14 bolt already converted.
08-19-2013, 08:54 PM | #14 |
Re: No spin?
Point me to where i need to look if ya would save me some muck scraping time, Thanks!
08-19-2013, 08:57 PM | #15 | |
Re: No spin?
http://www.google.com/imgres?q=Eaton...6geaOCTrG0M%3A
08-19-2013, 09:02 PM | #16 |
Re: No spin?
Thanks I'll check it out
08-19-2013, 09:24 PM | #17 |
Re: No spin?
The load bolt is used to prevent the ring gear from deflecting under load at the pinion gear (as in push away). It has a shoe that just floats against the ring gear under unloaded conditions.
08-19-2013, 09:38 PM | #18 |
Re: No spin?
Thanks for the explanation and pic, any idea what a proper clearance would be on it? i ask because the grease monkey at Jiffy lube thought it was to check the gear lube level, guess he never dealt with antiques before not sure if he messed it up but figure i should check the setting.
08-19-2013, 09:42 PM | #19 |
Re: No spin?
Thanks Tim..my 72 has the load bolt and I know for a fact mine is original to the truck. I just called the original owner and asked him I'm second owner
08-19-2013, 10:24 PM | #20 |
20' Daredevil (Ret)
Re: No spin?
It's a work truck, not a show truck, and it's a bit crusty underneath. A quick look found nothing. Where should the numbers be?
08-19-2013, 10:53 PM | #21 | |
Re: No spin?
08-19-2013, 11:14 PM | #22 | |
Re: No spin?
08-20-2013, 01:34 AM | #23 |
Re: No spin?
Don't know where you get these pic's but i sure wish i had that service manual! Thanks!
08-20-2013, 01:39 AM | #24 | |
Re: No spin?
I have all the No-Spin pamphlets and i'm fairly sure this is the stock unit, our family got this truck when it was a year old.. I'll find out soon enough I don't want to open it up until i have all the disk brake parts i need front and rear, as well as a new booster and am ready to do the swap, cant buy it all at the same time so trying to save some coin and then dive in with both feet.
08-20-2013, 02:04 AM | #25 |
Re: No spin?
You can download workable and searchable copies of both the factory service manual and the overhaul manual here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016 Really not sure you need rear disc brakes. The kits I have seen either don't use a park brake at all or rely on a poor mechanical design intended for a much lighter vehicle. If money is tight get your 72 front disc brakes up to as new with some quality pads, rotors, calipers and hoses. They do most of the work even more so on a lightly loaded truck. Then just go through and clean up the rears. Adjusted and working correctly they do a great job.
