#551 |
Re: Rustbuket 67 build "Georgia"
I just went through your entire thread at work (shhh... don't tell my boss). You've done quite a bit of work. I do have one question, if you don't mind. When you did your exhaust cut out in the cross member, are the pipe sections you welded in necessary, or just preference? I ask because I think this is the route I'm going to go with, but seeing the wedge cut into the factory piece, I'm thinking it was meant to have a little flex, and the pipe doesn't allow for that. Maybe I'm over thinking it? Nice progress, and great job so far.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#552 | ||
Thanks Nick!
Thanks Jim Thank you, I would like it a lot more if I didn't need to notch it ![]() ThANKS MJ Thank you Johnathan Quote:
I agree with you that the welded in section of round tube is not really needed. If you take a look at the ECE crossmember and other aftermarket crossmembers it is just a cut out. My reasoning was we only had 4.5" round at work so that is what I used. With the 4.5" my cutout was on the edge of the radius of the bend so I thought welding in the reinforcement would be a good idea. Ideally I would like to have used 3.5" round with no reinforcement. I work with engineers all day so I understand the overthinking, I do it all the time. slows me down ![]() ![]() I finished the tank notch and mounted the tank for the last time. I have been working on several other things and stocking new parts but the pic situation here is too much of a pain to post pics. I will try to sign up with photobucket in a while and try that out. We have also been taking care of a few things with an insurance claim at the house too, new roof, gutters going up right now, I have to paint the back porch,garage door and overhangs and have a new shed built. This is taking up much of my "spare" ![]() Ellie wants to post some smilies: ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#553 |
I love the picture from the back with the cab on the frame. Almost like looking at a womans backside. Great job with the fab of the notch.
![]() Posted via Mobile Device
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
#554 | |
![]() ![]() Attempting to link through photobucket. Trimmed the notch down getting ready to weld. ![]() Welded in, smoothed out just a little bit. ![]() Welded in with a little primer, it was raining on and off when I was trying to work ![]() ![]() Another shot in primer. Not the prettiest welds. I need to buy a bigger welder soon. The Millermatic at work has me spoiled. ![]()
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 08-03-2013 at 01:27 PM. Reason: added pic link |
#556 |
I will finish uploading and updating after lunch. Photobucket works pretty well. I dig it
#557 |
Lookin good there stud!
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#558 |
Thanks Chief, I have been watching your new build thread. Dont think I commented yet though. Looks like a great start
![]() Tank notch painted with tank installed, again.... ![]() ![]() ![]() ![]() I really wish the fill neck was .75" taller. If it were it would fit perfect between the frame and bed floor. Oh well done with it now ![]()
#559 |
Laid Back
![]() Join Date: Apr 2010
Looks good Dan!!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#560 |
These pics show how it is mounted directly to the underside of the frame. I used two 1/2" bolts on each side through existing holes in the frame. A typical receiver hitch wont fit with the Boyd tank but I found the CPP hidden hitch will fit. I may have to get one of them someday
![]() Driver side ![]() Passenger side This shot also shows some .25" rubber strips I cut on the shear to go between the tank and frame. Not sure if I need to use them or not. Any thoughts?? ![]() Here are a couple shots of the tank installed. Sure looks purdy ![]() ![]() ![]() I also torqued all the hardware on the rear and marked them with a sharpie so I don't forget ![]()
#561 |
![]() Join Date: Mar 2011
That sure looks nice, super job. I know you used lock washers and nuts to bolt in the tank, I think I would use locking nuts, just to be extra safe...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#562 |
Here are my rear shock relocators. I started these a long time ago but I decided I was going to copy robnolimit instead of this style. BUT the nolimit shock relocators would interfere with the Porterbuilt track bar bracket on the driver side of the frame. Sooo back to plan A.
Upper shock mounts removed and marked. Be careful they are not symmetrical. ![]() Cut them up with the plasma. Probably should have used a straight edge. They cleaned up fine on our vertical belt sander. Love that tool ![]() ![]() All cleaned up. ![]() Painted and installed. ![]() ![]()
#563 |
The idea on the upper shock re-locator is to move the hole up and BACK for more travel and to straighten them back up as before lowering.
Here is a link where I got the measurements. http://67-72chevytrucks.com/vboard/s...d.php?t=359399 Or you can just buy them from ECE or CPP. I am doing my lowers like the ECE and CPP version from my own measurements rather than modifying the stock lowers to work. Here is a pic of my experimental shock fitting jig. Once I decide on a hole to use I will make some out of 3/16. The lower mounts flip the tab down rather than up as original and maybe a little forward for better angle and more travel. ![]()
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car Last edited by 67c10rustbuket; 08-03-2013 at 03:36 PM. Reason: sp |
#564 |
Thanks Kyle!
Thanks Jim, You have a very good point. I was always told to use large flat washers when bolting aluminum like this but that kinda takes away from the lock washer doing its job. I will get some nylocs on there next time I go to the hardware store.
#565 |
Mounted the Idler arm bracket and idler arm. Moog of course
![]() ![]() I also have the pitman arm but cant put it on yet because I noticed my blasted/cleaned/primered steering gear started oozing fluid so I bought a gates reseal kit. waaaa
#566 |
Man of Mini-Talents
Dan, that puppies coming right along! All you lack now is finishing up.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#567 |
Everything is looking great! Have not been on here in way way too long and I am happy to see that you are doing a fine job at keeping on going. So many thing I love about your build!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
#568 |
Nice Clean Work!
#569 |
A day late and $1 short...
Read through the whole thread, and I am impressed! Great job on the rust repair and chassis looks awesome. I wish I was as resourceful as you are, keep up the pace and soon you'll be ridin'!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#570 |
Still Learning
Nice work on the shock mounts Dan. Keep up the hard work.
#571 | |||
![]() Quote:
Thanks Bompenstein!!! Quote:
![]() ![]() Thanks Mike! SO where was I? I punched holes in the rubber strips for between the frame and tank, installed them and changed out the nuts in favor of nylock lock nuts. Then I was messing around with some gas tank filler hose trying to figure where the filler will end up. I wanted it behind the rear wheel well in the floor but I really don't see how to make the turn up that close to the floor other than welding a sharp radius 90* pipe to a filler neck. Probably end up with a filler on the inner bedside or flush mount in the top of the bedside where the stake hole used to be. I will figure that out later once I put the bed together. I decided to go with a wood bed floor so I have a steel floor I need to get rid of. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#572 |
Now back to the rear shocks and lower mounts.
I decided to use this hole ![]() ![]() I cut the brackets with the plasma and smoothed the edges, and formed on the press brake. Time for a test fit. ![]() ![]() I ended up having to obround one of the holes because my u bolts are a hair over bent, Just to make installation easier. Then I made some gussets to add a bit of overkill to them. ![]() I put the new brackets on and installed new .5" x 2.5" bolts, press fit ![]() ![]()
#573 |
I bought some Monroe gas max shocks dirt cheap on rock auto and painted them to match the KYBs on the front
![]() ![]() Now that everything was clear I installed the shocks and snapped a bunch of pics, everyone loves pics right ![]() ![]() ![]() ![]() Paint was a little soft on this bracket ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#574 |
Now I have plenty of shock travel and it didn't cost me anything other than spare time
![]() Next up is the steering gear, When I blasted it and primed it fluid started seeping out of somewhere so I bought a seal kit. I removed the pitman arm nut and rented a pitman arm puller. Time to read the instructions ![]() ![]() ![]() ![]()
#575 |
I was able to change my seals out without disassembling the entire box. Just dig the old ones out with a pick or small screwdriver and tap the new ones in. I have done full rebuilds before and it's a pain in the butt and probably not needed.
Another 71 My truck In tank fuel pump how to LS factory gauges wiring how to-post 18 |
