Picks of stock retracting seat belt installed
Ran into a lil issue with the installation of a factory set of retracting lap belts, when I install them the lean into the door when it is closed, there is only 1 mounting hole in the floor to install, is the mounting hole the same as the shoulder belt mount?
Re: Picks of stock retracting seat belt installed
Anyone?
Active Member
![]() Join Date: Jul 2007
Here's an old one that I have. I'll look to see if I have others. And, if you need a particular pic I can get you one tomorrow.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Active Member
Here's another one I found.
Moderator
![]() Join Date: May 2007
If your truck is a 67, both the floor and shoulder mounts use a 7/16- 20 bolt (fine thread) 68-72 trucks use a 1/2- 18 bolt (course thread) for the floor mounts. All 67-72 trucks use a 7/16- 20 for the shoulder mounts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
Thanks 68gmsee, mine looks to mount the same spot but it leans on a 60-70 degree angle towards the door I will post a pick later.
They do have a little bend to them. Maybe you have the left and right switched. My 2 cents.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
