Old 08-02-2013, 11:12 AM   #1
slow-1
slow-1's Avatar
Tip for those who carry a spare tire in original location
A 235/70/15 wont fit.
I had new tires put on my truck the other day and had the guy save the best take off for my new spare since the old one had been under there since 1985.
The old tire was a 225/75/15 and was a tight fit.
With the new one, the original bolts were not long enough to fasten. I put a jack under the spare carrier and jacked it up as far as it would go, until the truck starting to rise, and no go.
I though about longer bolts, but I think it would have been hanging too low, especially after the planned lowering.
So I will have to find me a used skinny tire for a spare.
Probaly something everyone else already knew, but thought I would share just in case.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-02-2013, 11:50 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Tip for those who carry a spare tire in original location
I'm pretty sure I had a 235/75/R15 on my 69 and it fit okay. I'll have to double check that.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-02-2013, 01:16 PM   #3
Mister-B
I'm running 245 75 16 as my spare on the stock holder. Here's the tire and wheel
[IMG][/IMG]
Mister-B is offline   Reply With Quote
Old 08-02-2013, 01:22 PM   #4
slow-1
slow-1's Avatar
How far below the bottom of the license plate do your spares hang down?
Mine looked like it was going to be too low.
Old 08-02-2013, 01:34 PM   #5
FirstOwner69
FirstOwner69's Avatar
[IMG][/IMG]
I believe your 3/4 ton would have come with a carrier to accommodate a larger tie than the half tons did. Not 100% sure though.
FirstOwner69 is offline   Reply With Quote
Old 08-02-2013, 01:36 PM   #6
Mister-B
Had it like this for a couple months. No problems. It doesn't seem much different from the stock tire that was there before
Old 08-02-2013, 06:11 PM   #7
SS Tim
SS Tim's Avatar
How low is too low?
SS Tim is offline   Reply With Quote
Old 08-02-2013, 06:15 PM   #8
Mister-B
You're probably right. Seems like everything on this beast is a little more beefy
Old 08-02-2013, 06:31 PM   #9
slow-1
slow-1's Avatar
Mine looked a lot like yalls as far as distance below the tag, but my little C-10 is a lot closer to the ground.
Old 08-02-2013, 08:20 PM   #10
WIDESIDE72
WIDESIDE72's Avatar
We had a 235/75r15 under my dads 71 gmc with no problem. I forget a out adjustability of the carrier. That size is pretty close to the original bias tire size that came on 1/2 tons. Astro/Safari vans use a space saver in the 5x5 pattern if youre willing to go that route, but im not sure the spare tire carrier will tighten up enough!
WIDESIDE72 is offline   Reply With Quote
Old 08-02-2013, 09:45 PM   #11
slow-1
slow-1's Avatar
I think the difference may be the 70 vs. 75?
I am gonna try putting it under there again just for fun, since it was such a joy the last try...maybe I wasn't holding my mouth right.
I let the forward/left bolt out as much as it would go and had no luck.
It did cross my mind, a doughnut spare (mmm...doughnuts), but I can get a used tire for $10 down the street.
Old 08-02-2013, 10:56 PM   #12
tlcrz1972
tlcrz1972's Avatar
Upgrade to a newer model cable lift, and fabricate a mounting bracket and drive shaft for it.
With any size tire wide or not that original tire carrier will get hung on something (curb, speed bump, hamburger wrapper etc).
I've had the original tire mount way back when? And got tired of loosing the tire when the bracket got hung on something.
Since I put the cable system on it I never even concern myself about it, if I do go off a curb and it bottoms out it just slides right over.
tlcrz1972 is offline   Reply With Quote
Old 08-03-2013, 09:07 AM   #13
yuccales
yuccales's Avatar
Yep, this is one of the best things I've done to the old truck. I got a chain hoist off a Mitsubishi truck, some scrap steel, some bolts & nuts, job done for a bit over $20.00 bucks! Nice thing is, the crank handle is long enough that once the spare is lowered, I can unhook the chain and pull the spare out from under the truck without ever touching the ground! (because you know darn well your flat will happen when it's raining.)
yuccales is offline   Reply With Quote
Old 08-03-2013, 09:20 AM   #14
JointTech
JointTech's Avatar
the spare tire holder is garbage on our trucks. I had to take mine out the other day and needed a floor jack to take the weight off to release it. It would have really sucked on the side of the road. Oh and check your spare. Mine was flat and when I tried to fill it the dry rotted valve stem broke off. So now I have 2 tires with the tread seperated and 1 broken valve stem LOL. new wheels and tires on monday
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
