how much vacuum for power brakes
if im going to run an original power booster setup on my truck how much vacuum do you need?
70 longbed 496/th400/Ford 9" |
My son, my joy.
Manifold vacuum should be sufficiant.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Should be a port off the back of the carb(depending on what carb you have) that you can hook up the vaccum to..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
thats not what i asked. thanks tho. i have that port already its blocked off with a spark plug.... later on i will be going to aftermarket intake and carb and probably cam and one cam i saw advertised 10-12 inches of vacuum at idle and wondered if this is enough to run a power brake setup
PROJECT 7DEUCE
I got 30 inch's of vaccum on my 350 powered yota.. Brake's work killer..
is 30 a lot or a little? i dont know how much is a lot and how much is a little
would need aleast18- 20" of vacuum to run power brakes with any good pedal response....
30" of vacuum is kick buttt...... why what's you got? Last edited by rage'nrat638; 12-02-2003 at 11:20 PM. |
im running power brakes with about 8" of vaccum but without a vaccum canister that isnt possible and if you ride the brakes you will lose them
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
oh. havent thought about the vacuum canister thing. i want a good fast engine but i also need power brakes... the cam im looking at puts out about 10-12" of vacuum. i dont know bout my truck its stock except for hei and headers/duals and chrome air cleaner
Last time I checked, my blazer was running 16" vac and the brakes work just fine. My cam, intake and carb are not stock, so it runs a bit under stock specs.
with 10" of vaccum u can run power brakes you will just have to buy a canister. no biggie unless you use the brake pedal for a foot rest then you wont be able to stop when you need to
Formerly yellow72custom
I pull a little over 19" of vaccum with my truck (204/214 cam) and the power brakes work just fine.....no worse than when i had a completely stock engine.
Remember to stay fairly mild on the cam specs....what cam are you looking at? It will take a farily large cam to drop your vaccum into the 10-12" range at idle.....you don't want to stick a huge cam in a engine with stock heads and like 8:1 compression....even if you have a good induction and exhaust system.....it won't run very good and you will have crappy mileage and driveability.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
i was looking at an edelbrock performer rpm cam i think
http://edelbrock.com/automotive/cams_index.html but i wanna go with a comp cams cam. something not too radical but gives me good burnout power. ![]() i bought the comp cams master catalog and its frickin huge and has a cam for everything
You don't want tha Performer RPM cam in a stock motor.....it won't run very good. It is basically an old 292 cam....lift is over .500". It would proalby pull the pressed in studs out of a pair of stock heads in a hurry. To have a cam like and have the motor run good, you would proably need a set of heads that flow well at .500" lift, compression in the 9.5:1 or higher range, a high stall tourqe converter, and rear gears around 3.73 or lower. For a stock engine, converter, and high rear end gears, you would be much better off with something like a Crane 266, Comp 268H, Comp XE262, or something along those lines, with around .450" total lift and duration around 210 degrees at .050" lift. Then you would have a smooth idle, good low end power, good gas mileage, and more power overall than with a stock cam.
You should have plenty of burnout power with the smaller cam ![]()
#15 |
Thanks. what are you running? i like the old school lopey sound and thats kinda what i want in my truck but i guess a smooth idle would be ok....
#16 |
Right now i am running a cam that is too small for my motor, a Wolverine Blue Racer grind with 204/214 degrees of duration @ .050" lift and lift of .420/.442. Basically the same thing as a Summit 1102 cam. It did work good in my motor when it had 8.5:1 compression and 1.72/1.50 heads, but now that i have a better flowing set of heads on it and higher compression, it dosen't work that great. Stops pulling at a little over 4k rpm's. If i keep my 3.07 gears, i will upgrade to a Comp XE262. If i get 3.73's and the truck isn't my daily driver anymore, i will proably get a Comp XS268 mechanical solid lifter cam.
The 268H should have a nice lope at idle....every 350 i have heard with one sounded pretty good. Could defenitly tell there was a cam in there. The Crane 266 would proably be pretty a little smooter. I haven't heard an XE262 yet, but everyone says it will sound pretty healthy at idle, with a lope.
#17 |
For reference purposes the ZZ502 cam allows for roughly 12"...my brakes are "okay"...but not do to lack of vac....they need to be bled.
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
