Old 08-04-2013, 09:52 PM   #1
groove22
Air bag question
I have ran into a suspension problem and figured I 'd ask the experts. I've almost finished my ride tech kit on my 68 SWB, pretty easy until today. I ran into problems with the lower control arm's hitting the drivers side header, not sure what kind they are. Did anybody else run into this problem and if so what are some ways around it. I'm looking at shorty headers, block huggers or maybe a mid length. Any help would be appreciated. Its from Ride Tech and is the stage 2 kit.
Thanks,
Allen
groove22 is offline   Reply With Quote
Old 08-04-2013, 10:35 PM   #2
502ms
502ms's Avatar
Re: Air bag question
What motor do you have?
Doug Thorley's, BBK or Sandersons
I have BBKs and 6.0 LS
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-04-2013, 10:43 PM   #3
groove22
Just a 350, 5.7L. I'm leaning towards the Sanderson headers. I'm making a few calls tomorrow and will then talk to CINC House. That's sad I have to do that when its her truck I'm working on. I'll look at the BBK's. do you notice any difference with the shorty's, sound or performance?
Thanks,
Allen
Old 08-04-2013, 10:48 PM   #4
502ms
502ms's Avatar
Thanks,
Allen
Well, in my case it's night and day. I have a 6.0 LSx motor. Spins in 1st, 2nd and 3rd when I get/stay on it. I have a 6 speed manual.
Check out my build thread.
Best Regards,
Leon M.
Old 08-05-2013, 01:18 AM   #5
andrewmp6
Depends how bad they hit you could dimple the header if its not bad.
Old 08-05-2013, 08:54 AM   #6
groove22
Thought about that and the bolt would clear but I think the bushing would be to close to the heat.
Allen
Old 08-06-2013, 08:17 AM   #7
andrewmp6
Yeah roasted bushing don't sound like a good idea.
Old 08-06-2013, 07:42 PM   #8
groove22
Pulled the trigger on the Sanderson shorty headers yesterday. Looking forward to that install and finishing the suspension. Thanks for the advice guys.
Allen
Old 08-06-2013, 09:03 PM   #9
sduckworth13
sduckworth13's Avatar
What's the part number on the Sanderson headers? How low is your drop?
Scott
sduckworth13 is offline   Reply With Quote
Old 08-07-2013, 12:15 AM   #10
groove22
CC11 and the drop will vary. The truck is still on blocks. I did just jack the rear axle all the way to the bump stops and that is very low. The axle is close to even with the original part of the frame. If I had cut my bed up and probably removed the inner fenders up front I could lay frame, not my style though. Once I'm done I will post pics of the work.
Allen
Old 08-07-2013, 12:53 AM   #11
sduckworth13
Thanks for the info, check out Bennett-GL4 Build he is using the Hedman Elite 68618. I was thinking of buying a set of those. I actually shouldn't have a issue with my drop but might as well get some that work if I decide to go lower.
Scott
