Old 08-07-2013, 10:20 PM   #1
Aljohnsonii
1968 rear suspension questions
i have a 1968 gmc c15 2wd with the leaf suspension with the small rear end i think i want to put the coil spring setup in truck my question is will the coil setup from a 1966 chevy 1/2 work from what i can see it looks like the same setup and same frame but before i jump into it id like to get someone elses opinion or someone that has done it already
Aljohnsonii is offline   Reply With Quote
Old 08-07-2013, 10:38 PM   #2
marvgarr68
marvgarr68's Avatar
Re: 1968 rear suspension questions
Ok first why do you want to convert it? Second it will be alot of work not sure what you are trying to accomplish.
marvgarr68 is offline   Reply With Quote
Old 08-08-2013, 12:42 AM   #3
Aljohnsonii
i want a smoother ride and i like the springs alot better
Old 08-08-2013, 01:10 AM   #4
69SCSS
69SCSS's Avatar
I'm pretty sure that you can just drill / grind out the rivets and directly swap out the crossmember, they're the same 63-72. The frames are different at the core support area and a few other places slightly, but the crossmember is the same.
Edit: also don't forget the mount for the panhard bard on the driver's side behind the axle. if you have a 12-bolt that doesn't have the ear for the panhard bar you might need to change that out, don't know if the leaf spring ones have it.
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 08-08-2013, 01:16 AM   #5
Aljohnsonii
That's what I thought but wasn't 100% is the axles the same width or wider in 66? And does anyone know what size wheel spacer to put on the 68 to run the late model rims
Old 08-08-2013, 01:21 AM   #6
69SCSS
69SCSS's Avatar
I think the axles are the same width on 66's and 68's. They get wider on 70's and get 5-lug on 71's.
My 68 SWB
Al Silveira Music
Old 08-08-2013, 02:08 AM   #7
marvgarr68
marvgarr68's Avatar
Why don't you pull some leaves out for a smoother ride?
Old 03-23-2014, 08:54 PM   #8
Aljohnsonii
I eventually would like to go to a air ride set up. I have a 1964 chevy frame everything looks the same but the rear end it has a bracket welded to the axle instead of bolting onto the diff. Looks like only thing that would be different on this setup is the tracking bar is longer I'm going to start cutting robots tomorrow if weather allows
