Old 08-08-2013, 07:32 PM   #1
Chvy2NV
What size transmission cooler line ??
I'm going to be removing my hard lines from my transmission cooler and adding an external cooler. Question is, will -6 lines and fittings be ok to run??
Thanks!!
Chvy2NV is offline   Reply With Quote
Old 08-08-2013, 07:37 PM   #2
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: What size transmission cooler line ??
You probrolly would want to run it through the rad and the aux tranny cooler. Sorry that I didn't answer your question really.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-09-2013, 07:45 AM   #3
Chvy2NV
Bump
Old 08-09-2013, 08:38 AM   #4
Eddie H.
Eddie H.'s Avatar
AN-6 hose is approximately 3/8" ID , so it would be fine for trans cooler lines, as long as you use good quality hose that is rated for the pressure and temperature.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 08-09-2013, 11:37 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
As Eddie H. said, AN -6 is equivalent to 3/8" hard line so that is the correct size.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-09-2013, 12:42 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Originally Posted by blackedout67shorty View Post
you probrolly would want to run it through the rad and the aux tranny cooler. Sorry that i didn't answer your question really.
posted via mobile device
x2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-09-2013, 06:43 PM   #7
Chvy2NV
Thanks for clearing that up guys...
I was trying to avoid running the hardlines up to the radiator to keep it looking clean up there. Ive talked to several guys using this same setup with no issues.
This is the cooler im going to be running.
http://www.summitracing.com/parts/der-13266/overview/
