Closed Thread
Old 08-10-2013, 05:46 PM   #7626
In The Ten Ring
Re: What did you do to your truck today!
I picked up the Advance Auto radiator suggested to me on here (3 row) and I tore down my driver's side rear drum and cleaned all the parts. I think my adjuster screw/pivot nut is seized.
OK. Called NAPA and ordered both pivot nut/adjuster assemblies (both sides) and had them set me a set of brake drum springs aside as well. Gosh I hope I can get this all back together!
In The Ten Ring is offline
Old 08-10-2013, 08:48 PM   #7627
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I'm digging that new vintage air set up..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 08-10-2013, 08:52 PM   #7628
mmiddle
mmiddle's Avatar
Brought her home!
See my write-up in the main forum
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 08-11-2013, 12:00 AM   #7629
FRENCHBLUE72
PROJECT 7DEUCE
Got my new shocks mounted..
MEMBER #6377
Project "7DEUCE"
Old 08-11-2013, 12:08 AM   #7630
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
What are those? Do you remember $$$$$ ?
Thanks.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-11-2013, 12:09 AM   #7631
apacheben
apacheben's Avatar
tried fixing my brakes 58 chevy truck.
brake pedal does not return completely.
when I step on brakes.
brakes stay on while driving.
have to pull it up with my foot.
might need to put a spring on it.
apacheben is offline
Old 08-11-2013, 12:21 AM   #7632
FRENCHBLUE72
PROJECT 7DEUCE
They are bilsteins 123.60 each
MEMBER #6377
Project "7DEUCE"
Old 08-11-2013, 12:46 AM   #7633
farmall
farmall's Avatar
Installed newly covered bench and adjusted the clutch.
Ahh, comfy.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline
Old 08-11-2013, 01:05 AM   #7634
midniteblues
midniteblues's Avatar
scrapped and re blasted the underneth of my floors today.
I've blasted it once allready but the undercoating i sprayed on it afterwards didnt dry up in 4 months an i could still scrap it off with a fingernail.
so i scrapped as much as possible an started blasting again.
this time i'm doin epoxy an 503 on the bottom....cant go wrong there
i started the custom trans crossmember but i still cant do pics?
an i noticed i turned pink this week....truck budget is killing me
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 08-11-2013, 02:11 AM   #7635
67_C-30
I have a radical idea!
67_C-30's Avatar
Painted my gauge cluster and matched the grain on the glove box door. Also picked up a new beside today.
http://67-72chevytrucks.com/vboard/s...d.php?t=592128
New bedside -
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline
Old 08-11-2013, 04:05 PM   #7636
TBONE1964
Cluster King
TBONE1964's Avatar
I am getting some parts ready to switch everything back to original under the hood or at least as close as I can get it.
I sand blasted and painted all of the parts pictured. All of these parts were bought from board members. I am not sure about the black on the exhaust manifolds but it is extreme temp so maybe it will not burn off.
I have a few more pieces to collect and then I will tear it down and put the new parts on.
TBONE1964 is offline
Old 08-11-2013, 05:52 PM   #7637
Bennett68C10
Bennett68C10's Avatar
Primered my grill and blasted and primered the center support and hood latch. Hope to have the cab and the front clip bolted back on in a couple of weeks.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 08-11-2013, 06:20 PM   #7638
magwakeenercew2jh
This just in from the painter: His first color coat test on the new passenger's side rocker. I think I'm going to love the color.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-11-2013, 06:22 PM   #7639
70cst
70cst's Avatar
I took it out for a drive....
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 08-11-2013, 06:30 PM   #7640
nlped
nlped's Avatar
Great color!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 08-11-2013, 06:44 PM   #7641
mud.man.rj
mud.man.rj's Avatar
Changed the needles in my Edelbrock 750 and checked the complete truck over to drive 350 miles to the Saskatoon out door cruise weekend on Aug 23rd - 25th weekend. Will be a real cool time going with a few others from our area, they are trailering their cars, a 69 Charger, 69 Camaro SS and a recently finished 56 GM lowrider truck from our site (Dubie). Can't wait but will be some kind of gas bill with the big block.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 08-11-2013, 07:13 PM   #7642
FINE 69
FINE 69's Avatar
Power washed under the hood. I just picked up an all original 1 owner '69 Chevy SWB with the original 6 cyl w/3 on the tree about a week ago. Gonna give it a tune up so I can move it around while I'm working on the body.
FINE 69 is offline
Old 08-11-2013, 07:14 PM   #7643
BLACKLINE61
BLACKLINE61's Avatar
Originally Posted by Expat_dude View Post
Gen IV vintage a/c going in!
saw this on superflysteiny's build and seriously considering doing the same how much more difficult is it installing behind glovebox door rather than stock location?
BLACKLINE61 is offline
Old 08-11-2013, 08:23 PM   #7644
ksshane
ksshane's Avatar
Nothing exciting... oil change, plug change
71 swb 350/4sp manual 5/7 static drop
ksshane is offline
Old 08-11-2013, 09:34 PM   #7645
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today!
I drove it to the junkyard where the truck I saw over a week ago , was still there and 90 % untouched .
I took the core support out of it , came off fairly easily , only those two BIG @$$ bolts were rusted solid and fought me every inch .
Now to find some one with a sand / bead blaster that'll fit this 6' behemoth and get it cleaned up (surface rust along the bottom see pix) and find an honest paint shop to squirt it shiny black then I can install it along with my rust free right inner fender .
Bit by bit , piece by piece .
A guy came up to me to day and told he wants to sell me his old '66 LWB stepper with 250 I6 and Three On The Tree , it has some rust holes in the cab floor but looks worth saving or Hot Rodding , I have no where to store it else I'd buy it and break it for parts ~ the fenders , hood , doors , tailgate and windshield are all pretty good .
I just want the 250 as I'm beginning to despair of finding that elusive 292 to overhaul .
250 miles , 2/3 a tank of fuel , it's oil & filter change time again .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-11-2013, 11:48 PM   #7646
magwakeenercew2jh
Originally Posted by VWNate1 View Post
Now to find some one with a sand / bead blaster that'll fit this 6' behemoth and get it cleaned up (surface rust along the bottom see pix) .....
With all the nice stuff you do, you owe yourself a tasty sand/bead/media blaster.
I'm just sayin'.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-11-2013, 11:51 PM   #7647
magwakeenercew2jh
Originally Posted by nlped View Post
Great color!!!
Thanks, much. The boss (wife) and I are happy with the color sample.
Painter Lee says he's probably going to be done *early*. Now, it hasn't happened yet.
He has until 9/26 to still be on time.
But wouldn't that be a turn of events to what usually happens to us in paint jail (and, I guess some with some suspension parts ).
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-12-2013, 12:08 AM   #7648
VWNate1
VWNate1's Avatar
Thumbs up Re : Bead Blaster
I'm just sayin'.
Thank you Sir ;
I'm actually trying to finish up my current projects within three years when I retire .
I have a tiny yard and a crazy@$$ed drunken b*tch living next door to me who hates me and hassles me to death , she gave free BJ's to the local crooked Code Enforcement Officer so the City would come down on me ~ I won that of course and got him fired to boot but still and all , I'm getting old and want to drive more not continue rebuilding old vehicles .
I have one buddy who has a pretty big Bead Blaster but I doubt it's this big ~
the last time I needed it , someone had broken it after mixing all the abrasives up , I only had 15 minutes of blasting to do but he's running an Industry Fabrication Shop so I spent a few hours fixing the bead blaster then hand sifting the media into buckets using some screen I found in a corner .
To me this is better than having little used shop equipments lying around ~ I always leave the workplace cleaner than I find it , it's the right thing to do and keeps many doors open to me I'd never get in otherwise .
I think I'll begin by running a wire wheel in my drill motor , see how that cleans off the surface rust and overspray from the cheapo resale paint job this nice old junker had .
I'da bought the cab but the drip rail was rusted through in one area .
As I was working on it , older guys like me kept passing by and shaking their heads , asking me how a clean old work rig like this could have possibly been scrapped .
BTW : don't be thinking my Stepper is anything nice ~ it's a POC to be sure , I just try to to everything the best I can as I like to drive far & wide and want to be able to rely upon it .
Ask the fellas who've seen it , it's an incredible 20' er but up close it's nasty ~ structural rust throughout the cab .
-Nate
Geezer
VWNate1 is offline
Old 08-12-2013, 12:18 AM   #7649
magwakeenercew2jh
Re: Re : Bead Blaster
Thank you Sir ;.......
Yeah. I retired almost five years ago. And I've spent a good deal of the time during those years sweating in, over, and under
RAT. She's the second truck 67-72 build I've done. And, the last. Like you, I just wanna drive her.
Wasn't gonna get paint. But I decided to bite the bullet and get 'er done.
And, when I say, "the nice stuff you do", I'm the kind of guy that doesn't necessarily equate that with show-truck type of stuff.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-12-2013, 12:20 AM   #7650
Lee H
Lee H's Avatar
I've seen Nate's steppie up close, beautiful survivor. I would be proud to own it. I was saddened to hear about all the rust.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Closed Thread
