Old 08-11-2013, 11:40 AM   #826
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "Just an Old Truck"
Originally Posted by Hart_Rod View Post
That looks clean!!! .......except for..........the scratch under the radio..........
I guess I need to strip the interior and paint it now!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 08-11-2013, 03:30 PM   #827
C10_ustacould
Well, I wasted the better part of a day painting the firewall plates with paint that was way too expensive and didn't turn out the way I wanted. When they are good and dry I'll scuff them up and shoot them with some cheap semi-gloss black.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-11-2013, 10:10 PM   #828
Chvy2NV
What happened with the paint?
Chvy2NV is offline   Reply With Quote
Old 08-11-2013, 11:06 PM   #829
C10_ustacould
I ordered gm paint code 503 in an aerosol can from Automotivetouchup.com and it is just a little too fresh compared to my not so fresh firewall. I'm going to scuff them back down and repaint them in semi-gloss black. If and when I install the Porterbuilt suspension I'll try to smooth the firewall and have it painted the correct color. The problem I have is wanting certain things to be nice, like the firewall, but not having the talent or budget to do it. I know NOTHING about paint and body work, so unfortunately I am sort of at the limit of what I can do with this truck.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-12-2013, 08:34 AM   #830
Bennett68C10
Bennett68C10's Avatar
Sorry to hear about the paint Buck. I'm hitting a similar snag on my truck trying to pick up where my father left off with the bodywork. He is no longer able to do it due to medical reasons and well I'm certainly no bodyman and can't afford to just drop it off at a shop to do.
On a side note looking at your picture, you could probably mask everything off in the engine compartment, clean up your firewall and spray the whole thing, that way it would be uniform looking. You could even do it semi gloss black if you didn't want to do the light green. Did you have to clear over the green when you sprayed it or is that straight out of the can.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-12-2013, 09:36 AM   #831
C10_ustacould
I think I'm just going to paint them black and then worry about the firewall later. After all it's a patina truck.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-15-2013, 05:35 PM   #832
nlped
nlped's Avatar
Just read this entire thread in one sitting. Wow, super nice truck!!!
Why r u getting rid the the PB rear stuff? Air?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 08-15-2013, 07:05 PM   #833
C10_ustacould
Thanks for the compliment, you couldn't have better timing I needed to hear something nice about the truck. I am so PO'd at the truck right now I had to come in and calm down a bit. Things are just not going well today...
I am just going to go a different route to make it handle, it will be PB parts but no air.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-15-2013, 07:32 PM   #834
nlped
nlped's Avatar
Trailing arms should be great for handling... I'd think anyway. Wish I had the $ for that setup.
Carter
Old 08-15-2013, 08:01 PM   #835
C10_ustacould
Nothing cosmic, just some good shocks mounted in the right spots and sway bars.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-15-2013, 09:59 PM   #836
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking great!
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-15-2013, 10:26 PM   #837
C10_ustacould
Originally Posted by 1972SuperCheyenne View Post
Looking great!
Thanks brother!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-15-2013, 10:31 PM   #838
67_C-30
I have a radical idea!
67_C-30's Avatar
Awesome truck!
How much much did the aerosol paint cost you? Why not scuff the firewall down, maybe pull the master cylinder away from the firewall, tape up the wiring plug, and put some sheets or paper, etc. over the inner fenders and just spray paint the whole cowl with the paint you bought? It would really make the underhood area pop and being a firewall, it wouldn't have to be perfect.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 08-15-2013, 11:23 PM   #839
C10_ustacould
Originally Posted by 67_C-30 View Post
Awesome truck!
It would take more than I am willing to do at this point. One day down the road I'll take the front sheet metal off, the eng/trans out, and smooth the firewall the way I want it to look. Thanks for the suggestion though!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-17-2013, 04:08 PM   #840
Chvy2NV
Hey buck. Was just going back looking through your thread. And noticed you went with this external trans cooler. Did you also run it thru the radiator?? Also Seems like you used -8 lines or -6 ??
Truck looks great !!
A couple more things have been marked off the list... well one is are a redo. Transmission cooler is mounted and lines are built. I redid the front brake hard lines. and started to layout the engine wiring harness...
Old 08-17-2013, 06:17 PM   #841
C10_ustacould
I did not run mine through the radiator. It is an AFCO heat-sink style cooler mounted on the passenger side frame rail, and is connected using -6 braided hose.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-18-2013, 10:54 AM   #842
Chvy2NV
Thanks for clearing that up. That's exactly what I have. But some guys were saying I had to run it through the radiator. Also.
Thanks again. Keep trucking...
Old 08-18-2013, 11:09 AM   #843
C10_ustacould
Many will say it needs to go through the radiator too, but it seems to me that the radiator would heat the fluid. I guess time will tell, if the transmission burns up I'll know I need more cooling!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-18-2013, 04:05 PM   #844
C10_ustacould
Made some progress with the A/C today, wiring is connected but needs to be made "neater" and the flexible ducting is in, what a PITA! Well, because here are a couple...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-18-2013, 04:28 PM   #845
lolife99
67-72 parts collector,…
lolife99's Avatar
Great work.
Keith
Convert to disc brakes.
Old 08-18-2013, 04:52 PM   #846
STOCKISH
STOCKISH's Avatar
Looks great. Tight fit huh!?!
--Josh
Old 08-18-2013, 05:10 PM   #847
nlped
nlped's Avatar
No doubt!!! No glove box space there.
Carter
Old 08-18-2013, 05:44 PM   #848
Rusbuilt
Rusbuilt's Avatar
Nice work sir!
Rusbuilt is offline   Reply With Quote
Old 08-18-2013, 10:59 PM   #849
Bennett68C10
Nice job Buck
Keith
66 Suburban
IG: bennett68c10
Old 08-19-2013, 12:14 AM   #850
C10_ustacould
Great work.
Originally Posted by Rusbuilt View Post
Nice work sir!
Nice job Buck
Thanks guys for keeping me pumped up. I'm not sure how to explain this but I am not overly proud of how this is turning out but I know it's safe and functional. Well... I guess we'll see about functional when we charge the system. I'm building a driver, not a GG show winner but I have trouble accepting that at times. Like many on this board, I am limited by both budget and ability, and it is hard to see the builds turned out by Delmo or n2billet and fall so short of their genius. I think about what they would do and check their old build threads before I start an upgrade, and then I have to come back to earth, so it sometimes takes me some time to "settle" on a plan and execute it. This A/C install seems to be taking forever so I'm happy to see a glimmer of light at the end of the tunnel.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
