Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-11-2013, 01:04 PM   #26
Rannos
Rannos's Avatar
Re: 383 Build
I recently finished a 383 for my street truck. I can say that anything over 10 to 1 is a hassel on pump gas and Iron heads. mine is 10.2 to 1 and with out spicing 93 octane I get detonation at 6600 rpm unless i back my timing down to 33 or 34 degrees advance then she feels sluggish down low. I am using a much more efficient head then Vortec heads as well.
My engine specs are as follows.
Typical 383 4.030 3.75 stroke.
Probe SRS 2 valve relief flat tops with -4cc reliefs set .005 in the hole with Steelfire rings.
Scat rotating assembly.
RHS Pro Action 220cc heads with 72cc chambers.
Cometic MLS head gaskets that compress to .040.
Holley Strip Dominator intake.
Mighty Demon 750.
Comp cams xr286r solid roller. 248 exhaust 254 intake @.050 on a 110LSA and .585 .591 with 1.52 pro magnum rockers.
Mallory VI al cd box and promaster coil with a Mallory Unilite distributor.
Rannos is offline   Reply With Quote
Old 08-12-2013, 10:03 PM   #27
BigDan3131
BigDan3131's Avatar
Re: 383 Build
Rannos, that's a mild cam for that motor. You could have gone a little bigger and still been streetable.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-14-2013, 12:09 PM   #28
Rannos
Rannos's Avatar
Re: 383 Build
I know I could of gone with more cam but I didn't want the spring pressure that comes with it. Truck sees more street use and stop light runs then track duty. Plus it is built to take a decent amount of nitrous if I need it faster.
