Old 08-12-2013, 03:25 PM   #1
crakarjax
crakarjax's Avatar
Steering column to Intermediate shaft -- 1" or 3/4"
Hey guys,
I have a steering column and intermediate shaft that I *thought* I had pulled from my parts truck but now that I look at them a year later the column seems to have a 3/4" diameter spline and the intermediate shaft has a 1" splined opening. Am I just overlooking something here, or did GM make two different spline sizes? I believe the PO swapped from manual to power steering at some point.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 08-12-2013, 04:58 PM   #2
crakarjax
crakarjax's Avatar
Re: Steering column to Intermediate shaft -- 48 spline to 36 spline?
Ok I found through some digging that both 48 and 36 spline shafts are available. My column is 36 spline and the shaft accepts 48 spline. Is it possible to convert the intermediate shaft to 36 spline? It looks like the coupling part of the assembly could be swapped out... if I could find one.
Old 08-12-2013, 10:15 PM   #3
airdale94
airdale94's Avatar
Re: Steering column to Intermediate shaft -- 1" or 3/4"
I think you just get 48 spline coupler. http://www.jegs.com/webapp/wcs/store...eering+coupler
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 08-13-2013, 08:37 AM   #4
crakarjax
crakarjax's Avatar
I don't think that would work, I would need a 48 spline male by 36 spline female in order to attach my column to the shaft -- and I haven't been able to find such a thing.
I was thinking though, what if I got a DD x 36 spline U-Joint, and just lopped the intermediate shaft off a couple inches down? The shaft *looks* like it is DD but I haven't verified. I also don't know how much play is in the collapsible shaft.
Old 08-13-2013, 08:00 PM   #5
airdale94
airdale94's Avatar
I think I ran in to this same problem when I swapped my auto colum to manual. I think I wanted to use my orig. intermed. shaft and swapped the coupler. But I can't remember exactly. The shaft will collapse at least 4 or 5 inches once you get the plastic out of the pin hole, cause I shortened mine.
Old 08-14-2013, 08:26 AM   #6
crakarjax
crakarjax's Avatar
Thanks, that gives me something to work with. I like the look of aftermarket shafts but really, $150 for an intermediate shaft? No thanks!
Old 08-14-2013, 04:04 PM   #7
MARKDTN
You just need the intermedaite shaft from the steering box donor. There are 2 different splines on the boxes and either will work.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
