Old 08-12-2013, 11:12 PM   #1
Dynaride
Factory Tach Hook-Up
Trying to figure out how to hook up the factory tach and if it will work with my set up. 71 swb w/454 stock HEI dist on engine has a spot for the tach hook up. Only see a red and a black wire coming out of the tach, should there be three and how does it hook up? Research leads me to think red to switched 12 v black to ground and should be a green wire for tach input??? Any help is appreciated!
Dynaride is offline   Reply With Quote
Old 08-13-2013, 12:10 AM   #2
jons70
Re: Factory Tach Hook-Up
The instrument cluster itself is grounded so the housing on the tach is grounded already. The red wire is the switched 12V or as its indicated on the back of the tach and the black wire is the signal wire from the distributor. Not sure if the factory tach will work with the HEI, but I hope it does because I have the same setup as you. Haven't tried it yet, still finishing off the interior
jons70 is offline   Reply With Quote
Old 08-13-2013, 12:14 AM   #3
leddzepp
Moderator
leddzepp's Avatar
Factory tach will work with hei, never had a problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-13-2013, 12:25 AM   #4
jons70
Excellent! That's just what I wanted to hear after going through all the trouble to find a tach cluster and restoring it.Name:  IMG_0939(1).jpg
Old 08-13-2013, 12:36 AM   #5
farmall
farmall's Avatar
Good to know. I will be doing the same but my gauge face needs a face lift first.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 08-13-2013, 08:22 AM   #6
Dynaride
Thanks for the replies! Cluster looks awesome jons70!
Old 08-13-2013, 09:18 AM   #7
jons70
Thanks, good luck with yours. Its a nice touch to have the factory tach in there, rather then one strapped to the column
Old 08-13-2013, 09:26 AM   #8
Lattimer
Lattimer's Avatar
I just put one in my truck 2 weeks ago. Red wire to ignition hot, black to tach connection on the HEI. I did put a tach filter in line with mine jus tin case as I had read of some having a bouncy needle.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-13-2013, 09:27 AM   #9
NC_John
NC_John's Avatar
really? I read somewhere it wouldn't. That's great- my 70 was already switched to an HEI distributor and I didn't want to mount an external tach.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
