Old 08-13-2013, 01:41 AM   #1
wayno
Changing rear end angle.
So all the pieces are ready to go - engine in - transmission in - drive shaft bolted up - now trying to everything lined up - so from my reading I see that the tail of the transmission should be between 5 and 6 degrees and the pumpkin in the rear 5 to 6 degrees up - so can I just in between where the two meet in the rear to get the front of the pumpkin to turn down into the acceptable range and if so - should I put a couple of thick washers in between to act as a shim - how much variation can I really get this method... a half of a degree? Any thoughts greatly appreciated....
64 Step Side - The Mistress
wayno is offline   Reply With Quote
Old 08-13-2013, 06:43 AM   #2
DURG
DURG's Avatar
Re: Changing rear end angle.
I would make tapered shims but why so much angle? I have always shot for around 3 degrees tranny down? You have consistent research showing 5-6 degrees?
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 08-13-2013, 09:52 AM   #3
LEEVON
Moderator
LEEVON's Avatar
I don't have a link handy, but since these are the same trailing arms that NASCAR uses, there are some vendors that sell shim inexpensive shim kits. 5-6 degrees down is fine, like Durg said 3 degrees is pretty common also. Keep in mind the rear end will rise on accelleration from about 1-3 degrees. So you should aim for 3 up instead of all 5-6.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-13-2013, 10:55 AM   #4
padresag
engine-rear axle should be in the 3 1/2 degree range, that is usually where the relationship between your carb and crankshaft surface
ron
padresag is offline   Reply With Quote
Old 08-13-2013, 12:07 PM   #5
DURG
DURG's Avatar
Right - MOST Chevy intakes will set your carb level with the engine down 3 to 3.5 degrees at the rear.
Old 08-14-2013, 03:50 PM   #6
wayno
In doing some more research it looks like you are all correct calling for 3" down on transmission - at 5" ride height measured at the frame by the rear cab mount- I thought I had read somewhere that the pumpkin in the rear should be on a matching angle - should that be pointing 3" down as well... (I thought it was 3" up - but then my drive shaft won't pass through the trailing arms cross member - so I can't be right there) I am extremely outside my comfort zone here.... so much so that I just read article after article on pinion angle that I've stopped making any progress on my build. Any help greatly appreciated.
Old 08-14-2013, 03:58 PM   #7
geezer#99
geezer#99's Avatar
The centreline of the motor and the centreline of the rearend should be parellel.
If tranny is down 3* then pinion should be up 3*.
You need to set your pinion angle with the suspension loaded. Tires on, sitting on a flat surface.
There's a good chart in this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=569350
Old 08-14-2013, 05:15 PM   #8
DURG
DURG's Avatar
Also, if you are running a 5" frame height, you may need a 2 piece shaft. More pictures of your crossmembers?
Old 08-14-2013, 05:54 PM   #9
wayno
It's a porterbuilt rear cross member - running a tko 500 transmission (if this thing ever turns a wheel) - but I did discuss with them that I was running a one piece drive-shaft.
Old 08-14-2013, 05:55 PM   #10
wayno
These file limits are killing me
Old 08-14-2013, 05:58 PM   #11
wayno
so the thought process was to set the frame level at 5" inches - get the angle of the transmission to 3 degrees - drill and bolt in the transmission member... put the drive shaft in place and set the pumpkin up the same 3" - but I'm definitely not going to clear this thing with this one piece if that's the case
Old 08-14-2013, 06:32 PM   #12
DURG
DURG's Avatar
What is the angle in this picture of the TKO ? Looks steep.
Old 08-14-2013, 07:34 PM   #13
wayno
It's super steep - maybe 10-12 degrees in the picture - the transmission cross member is just laying in the bottom of the frame rails - the thought process was to hook up the drive shaft - crank up the rear of the transmission to 3 degrees and then bolt drill and bolt that and then get the rear pumpkin into the right position - but I was leaving it sort of in the breeze until I was sure I could get the angles I needed.
Old 08-14-2013, 07:52 PM   #14
DURG
DURG's Avatar
You need to:
1. Set your frame at desired ride height. I would put at least a half inch if not an inch of rake front to rear
2. Install motor at the correct angle. Say 3 to 3-1/2 degrees down at rear.
3. Set pinion angle at opposite EQUAL angle as tranny. Yoke up the 3 to 3-1/2 degrees.
3. See if a one piece driveshaft will work for you through ALL the suspension travel you plan on using. Are you going to lay frame? You need adequate clearance with shaft here too!
4. Determine if the cross member you want to use will work with the one piece shaft.
Old 08-14-2013, 07:53 PM   #15
geezer#99
geezer#99's Avatar
You're going about it bassackwards!
With your motor in the frame sitting on the front suspension with wheels/tires installed, set your carb level and then install your tranny mount. Leave the rearend alone until you have the rest of the weight on the truck. Then set your pinion angle and install your driveshaft. At that point in time you'll know whether you need a one or two piece driveshaft to clear your truck arm mount. Otherwise you're spending a lot of time mocking up what you might need to change later.
JMHO
Old 08-14-2013, 07:57 PM   #16
DURG
DURG's Avatar
Put it this way I have a Porterbuilt touring setup with coilovers with a 6" rear ride height. When I am on the stops in the rear at about a 3" frame height, my one piece 3-1/2" od shaft just BARELY clears the cab. I had to modify my mid crossmember heavily for clearance but I have a four link so no big deal. Check my build thread for some pictures just for reference if you are interested.
Old 08-14-2013, 10:09 PM   #17
wayno
No that makes sense to me guys- I guess where I was going awry is expecting given the entire thing is porterbuilt - front to back and they knew I had a once piece as that was part of the discussion (are your going to run a 1 or 2 piece drive-shaft) that I was feeling I was doing something wrong - with the transmission at the correct angle I would have to cut right through the top of their trailing arm cross member (obviously it looks like I'm going to have to run a two piece - but I was working on the basic assumption that they have this set up down to a fine art why ask if I was running a 1 or 2 piece unless that's taken into consideration - I'm waiting to hear back from Nate and Team but definitely looking like I blew a couple of hundred dollars getting that drive shaft shorten and the new U joints
