Old 12-03-2003, 04:38 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
clutch pedal linkages
as yall know i have a 76 C10 that has a 250 I 6 motor in it with the three on the tree. Recently because of rust issues ive replaced the entire cab with a 81 C20 cab.The 81 cab used to be a standard shirt cab too cause the brake pedal is one of the real small onesMy question to you all is is there any difference between the clutch linkages from, 76 to 81 cause i stripped out almost every part i could out of the 76 cab .i want to blot this up as painlessly as possible Do i need to use the clutch assy out of a newer ( 81-87 ) truck?
Ive already swapped over the wiring harness and the column
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-03-2003, 04:54 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you are putting the whole assembly in there, you won't have a problem. I put a 73 in my 86 cab for mock up purposes. Techically, as long as you put everything from cabA and put it in cabB, you won't have a problem. It is when you start miss-matching parts that you have problems.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-03-2003, 06:23 PM   #3
old Rusty C10
now i left the metal that was riveted into the cab which the cluthc pedal bolts through( brake pedal too) is that going to make a difference?
Bob
I hate cancer!!
Old 12-03-2003, 08:15 PM   #4
Captkaos
Captkaos's Avatar
You are talking about the large shaped piece just to the right of the firewall clearance right? They will be the same, BUT, depending on the setup of the donor, you might either have 2 holes missing, or 2 extra.
Can you point it out in this pic what you are talking about:
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-03-2003, 09:37 PM   #5
old Rusty C10
the piece of metal i was referring to is the one inside the cab its under the dash and athe column bolts up to it and the brake and clutch pedals go into it
Bob
I hate cancer!!
Old 12-04-2003, 02:12 AM   #6
Captkaos
Captkaos's Avatar
Oh, the complimentary one to the outside. They will be the same, You don't need to "unweld" anything.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
