Old 08-13-2013, 07:58 PM   #1
mexlokote
mexlokote's Avatar
Exclamation help me start my 305,
I recently bought a 305 engine out of a 1976 Chevy c10
Now I was told it works good,
But I have some concerns if it really does work,
I have it in an small engine stand I want to try to get it started before I drop it in on my truck
I have never done this before,
I just want a simple start, maybe have it running for 10 mins,
I want help on how to do the wiring and all that stuff
Some diagrams would help!
mexlokote is offline   Reply With Quote
Old 08-13-2013, 09:10 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: help me start my 305,
Battery power to the distributor. Ground the engine and battery to stand power to big terminal on starter. Small terminal closes to the terminal is ignition switch for the starter. Have a radiator and some water for ten min running time.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-13-2013, 10:39 PM   #3
mexlokote
mexlokote's Avatar
Thank you!
Old 08-13-2013, 11:12 PM   #4
INSIDIOUS '86
Before you wire it up remember a toggle switch between the battery and distributor so your able to shut it off
Old 08-13-2013, 11:55 PM   #5
mexlokote
mexlokote's Avatar
Wont forget that! Thanks again
Old 08-14-2013, 01:11 PM   #6
tommartin
tommartin's Avatar
did it start?
lets see some pics...
tommartin is offline   Reply With Quote
Old 08-14-2013, 01:54 PM   #7
mexlokote
mexlokote's Avatar
I have a wire running from distributor to battery and I have the big wire running from starter to battery also I have the ground from engine to battery, what else do I need to wire up?
Old 08-14-2013, 03:58 PM   #8
INSIDIOUS '86
The signal wire to the small terminal on the starter. Hook that up to a button and when under power it will crank the engine over
Old 08-14-2013, 04:17 PM   #9
geezer#99
geezer#99's Avatar
Originally Posted by tommartin View Post
did it start?
A video would be nicer!
Of it flying around the shop if you don't use a proper engine run stand!
Old 08-14-2013, 04:32 PM   #10
mexlokote
mexlokote's Avatar
The starter does spin, but I noticed that the flywheel is short and doesnt even touch the
Starter,
the engine I bought is from a manual transmissiom, and the flywheel I have is from a automatic transmission,,
U found some info online that it says the starter from an auto trans is different from a manual trans,,,,, maybe thats the issue??
Or I have a wrong flywheel?
Old 08-15-2013, 02:04 AM   #11
INSIDIOUS '86
Is it not reaching when it comes out or is it like the flywheel is to small?
Old 08-15-2013, 02:11 AM   #12
mexlokote
mexlokote's Avatar
Too small I measured the diameter and its 13inch,
Provably one more inch and it will make contact,
Old 08-15-2013, 01:23 PM   #13
INSIDIOUS '86
You prob have the 153 tooth flywheel. Try a starter for that style flywheel
Old 08-15-2013, 10:12 PM   #14
mexlokote
mexlokote's Avatar
I took it to autoparts store and I bought the right one,
I bought one from 70's
The one I had was from an 80's engine
So I got it home and installed it, I bought some gas, and hopefully tomorrow I will try to start it
Old 08-15-2013, 10:23 PM   #15
1slo_camaro
do you have this on an engine stand like one you can buy at autozone for like 40 bucks? or an engine run stand? even just to start it the rattle of the motor can easily tip that engine stand over and do a lot more damage thenyou will desire....
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 08-15-2013, 10:27 PM   #16
mexlokote
mexlokote's Avatar
I bought a 1,000LB engine stand for $60
And just incase I have a heavy duty cherry picker holding the engine,
Incase if flips over the cherry picker will definitely hold it
Old 08-15-2013, 10:29 PM   #17
1slo_camaro
idk if id leave it running for 10 min, but that is just me, I have had a big block spin completely over before and luckily all it did was trash my valve covers and that was on a 1500lb stand with 4 bags of sand on the legs so i built an extremey sturdy engine run stand that has witheld me taking a big block up to 3500 rpm
Old 08-15-2013, 10:39 PM   #18
mexlokote
mexlokote's Avatar
Im not gunna be running it hard and probably not for 10 mins
I just want to make sure it doesnt have any wierd sounds or knocks,
Old 08-15-2013, 11:27 PM   #19
geezer#99
geezer#99's Avatar
I still say take a video of it! So we can all see it bouncing around the shop!
An engine stand and a cherry picker isn't going to slow it down. Better to start it on the floor.
Old 08-16-2013, 12:37 AM   #20
mexlokote
mexlokote's Avatar
i will take a video lol
Old 08-16-2013, 01:05 AM   #21
mexlokote
mexlokote's Avatar
does anyone know how to wire the alternator on engine stand??
that way when im in the process of rebuilding i can test it and wont have to keep charging my bettery
Old 08-16-2013, 05:22 PM   #22
INSIDIOUS '86
I'm in the process of wiring up my engine now. I do know that the bolted terminal on the alternator goes to the main starter terminal were the battery cable connects
Old 08-16-2013, 05:25 PM   #23
1slo_camaro
how often do you plan on running it? lol but the main post should go to your battery power. and as far as i know you should be fine as long as you arent running for hours on end
Old 08-16-2013, 10:16 PM   #24
mexlokote
mexlokote's Avatar
here is the video, i was not able to keep it running, it kept shutting off,
the guy i bought it from told me the carb had water in, so im guessing carb doesnt work,
but i do have an extra Holley carb,
also the carb was leaking gas everywhere, so im asking you guys how do u hear the engine? is it good?
it does start right up but it shutts off cuz theres not enough gas getting to carb
Old 08-18-2013, 09:20 PM   #25
mexlokote
mexlokote's Avatar
successfully started my engine!!
i installed the other carb had in my shop
its a Holley 650 double pumper
it starts right up,
here some videos,
it does not shake too much on the engine stand and cherry picker that are holding the engine,
