08-17-2013, 10:41 AM | #1 |
Grounding Straps
anyone have a source for grounding straps? I will have the negative battery cable grounded to the block, but I was advised to have at least 1 additional strap grounded from the block to the frame as well. LMC does not list these.
Any pointers for me? How do you have your truck grounded Thanks Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
08-17-2013, 11:05 AM | #2 |
Re: Grounding Straps
Step by steps: Remove primer to reveal original paint Rebuild a carburetor See My Build - Cecilia! Some people are like slinkys. Not worth much but funny as heck when pushed down stairs. |
08-17-2013, 11:13 AM | #3 |
Hi Jake check this link out I'm posting there is also a guy on the forums that sells headlight upgrade kits that has ground kits also. I don't have the link to that one but you can find it on the search on the forums..Vernski
http://www.ags.bz/ |
08-17-2013, 11:15 AM | #4 | |
Posted via Mobile Device |
08-17-2013, 11:46 AM | #5 |
You can also make yourself a set- I have used 10ga wire with crimped and soldered ends in any length.
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
08-17-2013, 12:03 PM | #6 |
MusicMan70 1961 GMC Suburban |
08-17-2013, 12:22 PM | #7 |
One of the most-important, often forgotten items when guys are putting their stuff together. Gotta have em!!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
08-17-2013, 12:52 PM | #8 |
Thanks guys that quick will check autozone first then the other sites
08-17-2013, 01:58 PM | #9 | |
We manufacture ground straps for all chevy trucks, so we do have in stock straps to fit your truck, instructions included for the mounting points. Part number 6066GSK. Thanks http://67-72chevytrucks.com/vboard/s...d.php?t=511271 |
08-17-2013, 02:00 PM | #10 |
Moderator
block to frame, block to cab, frame to body (both cab and bed)
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
09-09-2013, 02:00 PM | #11 |
These are just what I need...PM sent!
thanks, Greg |
