Old 08-17-2013, 07:56 PM   #1
jd21476
jd21476's Avatar
Door speaker install- how to?
My '73 has cut outs in the doors for 5-1/4" speakers. I just bought a set to install but I can't figure out how to run the wires in to the cab. I don't see a hole in the cab to run it through. Any ideas?
jd21476 is offline   Reply With Quote
Old 08-17-2013, 08:15 PM   #2
nheller76
nheller76's Avatar
Re: Door speaker install- how to?
Drill one? That's what I did
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 08-17-2013, 08:32 PM   #3
tex_waco_usmc
Project Heaven in my 67!!!
Go to the wrecking yard and pull a truck apart that had PW, PL and use the original boot from it. measure the holes and cut it exactly like they are and it will give it a more factory look. Just an idea.
tex_waco_usmc is offline   Reply With Quote
Old 08-17-2013, 09:38 PM   #4
izzy_Britton
izzy_Britton's Avatar
+1
once you get the boots (available aftermarket or oem still), problem is you gotta remove the door to do it right. if you look at the door jamb on the cab AND the door, you might see 3 little indention on both, the middle hole is for the wires while the other 2 (top and bottom) are for rivets or screws to hold the boots to the door/cab
it is worth the extra work, in the mean time locate the indention and drill small 1/4 hole, run your wires and put some of that flex wire saver crap you get at the parts house on it, and a rubber grommet to keep from cutting the wires on the newly drilled holes.
-Izzy
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 08-18-2013, 11:09 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
not the right way to gain access lol , but that's the boot
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 08-18-2013, 12:45 PM   #6
izzy_Britton
lol @ motornut
Old 08-18-2013, 09:10 PM   #7
jd21476
jd21476's Avatar
Looks good. Thanks
Old 08-18-2013, 11:04 PM   #8
tex_waco_usmc
I don't see a problem with the way you gained access as long as that isn't your truck that you did that to! LMAO JK
Old 08-19-2013, 01:35 AM   #9
Billy81
Billy81's Avatar
If i remember right i think Motornut had a little help from a drunk driver. While we are on the subject of installing speakers in the doors. Has anyone tried the Boom Mat speaker baffles? http://www.designengineering.com/cat...peaker-baffles
Billy81 is offline   Reply With Quote
Old 08-19-2013, 02:15 AM   #10
bigwheel15
bigwheel15's Avatar
Those baffles are good for keeping your speaker dry, cut the backs out of em though.
bigwheel15 is offline   Reply With Quote
Old 08-20-2013, 10:48 AM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
that was the problem it was my truck,and I did'nt do it
I've seen people use heavy plastic sheeting/sealer instead of those type much better the plastic sheets just shred
John
Old 08-21-2013, 12:39 AM   #12
izzy_Britton
I had a set of these in one of my trucks forever ago, they were not this brand but similar, and i believe they may have been a factory item from another car installed by the PO of that truck. they seemed to work, i didn't own it long enough to say if they worked good or bad.
