Old 08-18-2013, 10:29 PM   #1
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Question about rear power window
On an 84 suburban. I put the key in to roll the window down and the dome lights dim but window doesn't roll down. Bad motor, or switch? I never had one with tailgate, only barn doors. I tried to search the forum but it didnt work.
13 Corvette GS vert
13 Ram Laramie Longhorn
11 Wrangler Sahara unlimited
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
08 HD Road King Classic
68 HD Golf car
StepinNJ is offline   Reply With Quote
Old 08-19-2013, 07:15 AM   #2
tobiahr
tobiahr's Avatar
Re: Question about rear power window
try doing it with the engine running...some of the older switches don't allow enough amperage and some of the motors can be weak and the additional amperage from the alternator can help. could also just be a stuck window. have someone push down on the glass with the switch engaged.
tobiahr is offline   Reply With Quote
Old 08-22-2013, 05:35 PM   #3
Ak. Mal
The power wire for the keyed window switch has a weather proof quick disconnect behind the bumper. I found my power wire to be corroded enough that I was only getting 5-6V at the switch. Enough to dim the light, but not operate the motor. I replaced the corroded section and now with 12V at the switch, the window works fine. Before this repair, I could only operate the window from the dash.
Ak. Mal is offline   Reply With Quote
Old 08-22-2013, 09:42 PM   #4
StepinNJ
TuTone Silverado
StepinNJ's Avatar
I will check that out. It doesn't even work from the dash though.
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
Old 08-23-2013, 12:38 AM   #5
tobiahr
tobiahr's Avatar
you can also check and make sure the cable isn't messed up. Mine has a cable from the motor to the regulator like a speedometer cable that can get either dry or sticky.
Old 09-01-2013, 11:57 PM   #6
StepinNJ
TuTone Silverado
StepinNJ's Avatar
Got new battery, window works with key in back door, but not with dash switch.
13 Corvette GS vert
08 300
76 El Camino
67 Bel Air sedan
63 Corvette SWC
68 HD Golf car
