Old 08-19-2013, 08:11 PM   #1
loom34432
loom34432's Avatar
trailing arm bushings
Has anyone had difficulty in replacing their trailing arm bushings? I've got the poly ones and they are HARD to get in. What's the easiest method?
72 C10 350/TH350
loom34432 is offline   Reply With Quote
Old 08-19-2013, 09:24 PM   #2
kaycee
kaycee's Avatar
Re: trailing arm bushings
I used a big C-CLAMP and some poly grease
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-20-2013, 09:43 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Make sure the outer shell is nice and clean inside. A drill and a sanding drum might be required. You don't want any remnants of the old rubber bushings left in there to hinder installing the new ones. Then, grease and press like the guy above said.
Tx Firefighter is offline   Reply With Quote
Old 08-20-2013, 01:13 PM   #4
tinydb84
tinydb84's Avatar
Freeze the bushings. It will give you a tiny bit more space
David
Instagram: myfabguy
Old 08-20-2013, 07:49 PM   #5
GEARBOXGARAGE
Tag team these to recommendations and you should be set!
GEARBOXGARAGE is offline   Reply With Quote
Old 08-20-2013, 10:03 PM   #6
loom34432
loom34432's Avatar
Hey thanks everyone!! I have sanded them clean on the inside, but did'nt think about freezing them. Thats good idea, frozen and poly lubed, they should jump right in.
72 C10 350/TH350
