Ujoint trouble
Hey guys and girls haven some trouble on my 71 gmc long bed. It has a two piece drive shaft. Well it needs a new center ujoint right after the carrier bearing. Haven trouble getting it out popped out the clips soaked it in rust penetrator and can't get it out. What am I not doing? Thanks for the help
Posted via Mobile Device |
Re: Ujoint trouble
Support the yoke on a solid place (vice works) and put a socket inside where the clip was and wack it with a bfh. It'll come out. You can put a bigger socket on the other side of the yoke too and do it on a cement floor.
Get your frustations out and beat it to death! |
Re: Ujoint trouble
Yes, grab the BFH and beat it to death. Then you'll be buying a new yoke. Best to get the right tool to press it out or take it to a machine shop. The cost of a machine shop will be less than buying a new yoke and then getting it put together. You also need to keep the phasing right or it will vibrate. On a drive shaft BFH = $$$$.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
I am a Referee of life.
Re: Ujoint trouble
Or you can take a large vice and set it up with a socket large enough for the cup to fit in on one side and a socket smaller than the outside diameter of the cup on the other side.Tighten the vice and the cup on one side should come out.Then turn everything around and do the other side.
They can be a pain to get out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Jun 2013
Re: Ujoint trouble
This is a little confusing. Are you having trouble getting the clips out or the bearing?
Gale Gorman '54 3100 '67 C20 stepside |
#6 | |
Re: Ujoint trouble
Re: Ujoint trouble
Ok guys got it used the sockets with the vice plus a little heat. Thanks for all the tips
