Old 08-20-2013, 10:57 PM   #1
kaycee
kaycee's Avatar
Drop Shocks
Any body got a rferance # for a drop shock I dropped my truck 4" now I need some shorter shocks for the rear.I used springs for the drop and just need some in expensive shocks.Sure would like to go into ADvance Auto or ?? and give a part # .Not to concerned on brand THANKS
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-21-2013, 08:00 PM   #2
kaycee
kaycee's Avatar
Re: Drop Shocks
Nobody has found an alternative shock to use,How do I measure to find the correct travel I need.
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 08-21-2013, 09:46 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop Shocks
I normally use KYB shocks from Early Classic Enterprises.
Keith
Convert to disc brakes.
Old 08-22-2013, 09:13 AM   #4
kaycee
kaycee's Avatar
Re: Drop Shocks
Thats what alot of people do ,just figured I could find something else that would work.
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 08-22-2013, 10:09 AM   #5
67c10rustbuket
67c10rustbuket's Avatar
Re: Drop Shocks
http://67-72chevytrucks.com/vboard/s...d.php?t=331653
Lots of shock info and PNs in here.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 08-22-2013, 06:51 PM   #6
kaycee
kaycee's Avatar
Re: Drop Shocks
All right thanks for that info
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 08-23-2013, 01:41 PM   #7
cdog73
Re: Drop Shocks
I have over a 4" drop on the rear of mine and i used stock front shocks.
cdog73 is offline   Reply With Quote
Old 08-23-2013, 08:31 PM   #8
kaycee
kaycee's Avatar
Re: Drop Shocks
I made some top mounts and got my shock to sit more straight,put my original shocks back on.Will get some shorter shocks this winter(maybe)
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 08-24-2013, 09:09 PM   #9
cdog73
Re: Drop Shocks
Trust me the stock front shocks work great on the rear. A lot of people on this board use them as a good cheap smaller shock.
Old 08-24-2013, 10:25 PM   #10
kaycee
kaycee's Avatar
Re: Drop Shocks
OK I took it out today and ran a little over a hundred miles ,they did bottom out on the bad bumps.You wouldn't happen to have a part # would you THANKS
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 08-24-2013, 10:30 PM   #11
chevy-fun
chevy-fun's Avatar
Re: Drop Shocks
when you use the front shock for the rear. do you still have to use shock extenders??
chevy-fun is offline   Reply With Quote
Old 08-24-2013, 11:13 PM   #12
kaycee
kaycee's Avatar
Re: Drop Shocks
If u lowered the rear like I did somewher around 3 1/2" to 4" then I would recomend to relocate the shock top or bottom.I did and it drives like a differant truck now.My stock shock Monroe gas matic #56001 19.5"extened and 12." collopased will bottom out on a agressive bump/dip etc.. I looked on line (Adv.Auto)and found some Monroe #59041 that are a little shorter 14.6" extended and 10.1" collapsed
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 05-09-2014, 04:19 AM   #13
parkinglot
parkinglot's Avatar
Re: Drop Shocks
Just a note that I havent seen posted. I used a spring block combinatiin on my rear, and front shocks are too short with relocator brackets to work...
72 C-10 long bed 350 3OF
07 classic Z-71 xcab L-33
parkinglot is offline   Reply With Quote
