08-20-2013, 11:07 PM | #126 |
Re: ls turbo build
Thanks.... Things have been pretty tough around here for us.... This truck is all i have that dad and i worked on together, and it kind of calms my spirit when i work on it....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
12-02-2013, 10:27 PM | #127 |
Re: ls turbo build
awesome build.
12-03-2013, 03:35 AM | #128 |
Always a work in progress
Re: ls turbo build
Just an FYI(not bashing your setup bc it works too) but a 4150 style TB and an Extreme Velocity Carb Hat will get you some better numbers. I am going to go that route but with a Super Victor.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
12-03-2013, 02:50 PM | #129 |
Re: ls turbo build
Thanks... I've checked into various ways of doing the intake and tb. And on the turbo forums and yellowbullet everyone with turbo setups that i've been talking too have said the way i have it is the better way. Just need a spacer to get the air to transistion better in the runners.. Plus there is a truck here in oklahoma making around 1200 to the wheels with an elbow and spacer.. It's on street outlaws... Personally i don't know.. But this was a pretty cheap set up that i bought used...
12-04-2013, 02:48 AM | #130 |
Re: ls turbo build
I've heard it the other way and I have also heard of the spacer to help staighten the air out as well. I can't remember the company but they make some damn good elbows, when I find them I will give you the link. I can't decide on what intake I want to run it's either the ProFlo or Super Victor/4150tb. I'm probably gonna stick with the truck intake until I upgrade or hurt the motor. I can't wait to see results, I have been itching to work on mine but I have only been here in Japan for 5 months and I have another 2 1/2 years to go. FML
12-04-2013, 02:51 AM | #131 |
Re: ls turbo build
6061.com is the site. Supposed to be the best flowing elbow. BTW I wouldn't have passed up that deal either. How did you route your fuel lines? is your regulator before or after your fuel rails?
12-04-2013, 07:43 AM | #132 |
Re: ls turbo build
After the fuel rails.. Ill get some pics. up later... I was also going to go with the proflo intake mainly because it looks bad a--. The only problem i had with the fuel rail plumbing is one of the sweeping 90 deg. elbows was going to interfere with the back of the alternator. SO i changed it to 90deg. elbows to shorten them up.. Have truck acc...
12-05-2013, 07:00 PM | #133 |
Re: ls turbo build
Thanks for the replies. Keep us updated bc I have to live vicariously through other peoples trucks right now.
01-24-2014, 12:28 PM | #134 |
Re: ls turbo build
Any updates?
01-25-2014, 10:54 PM | #135 |
Re: ls turbo build
not alot.... new baby and still dealing with my dads stuff which is 280 miles away... I did buy a ac compressor bracket. Looking for some c6 exhaust manifolds. Then im buying a complete new vintage air system next... Everything i have left is very expensive...
01-26-2014, 01:12 PM | #136 |
Re: ls turbo build
I have a BRAND NEW pair of C6 exhaust manifolds off a LS3 crate engine, never used. I even have a pair of the flanges from the converter side....
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
01-26-2014, 09:00 PM | #137 |
Re: ls turbo build
pm sent
02-05-2014, 04:13 PM | #138 |
Re: ls turbo build
How it been going? I ended up selling my 88mm and getting a s475.
02-06-2014, 10:38 AM | #139 |
Boosted Member
Re: ls turbo build
Which 475 did you get? Cast or billet?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-06-2014, 10:49 AM | #140 |
Re: ls turbo build
I got the cast one for my truck
1.1 ar T6 housing 83mm wheel |
02-06-2014, 12:58 PM | #141 |
Re: ls turbo build
Cool build. Just got my LQ4/4L80e last week. Debating now on H/C/I or cam and turbo. Goal is less power than yours is going to be. Can't wait to see the results.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
02-06-2014, 11:28 PM | #142 |
Re: ls turbo build
What kind of Hydroboost set up is that you are running? Where can I get one and how much was it Sir?
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" 68 GMC K1500 1/2 ton L83/6L80e |
02-07-2014, 06:32 AM | #143 |
Re: ls turbo build
The hydraboost is by hydratech. It was $783...
Thanks for all the complements, things are just kind of slow right now....
03-19-2014, 06:46 PM | #144 |
Re: ls turbo build
what exactly did you order from hydratech? not sure which one to choose because they dont list one for our trucks...thanks
08-27-2014, 10:08 PM | #145 |
Re: ls turbo build
Started back on the ol truck again... mounted the tranny cooler behind the cab under the bed and installed an electric fan... just ordered vintage air from a vendor on here called Laid Back Recreations...ill post some install pictures as soon as I start on it which will be in a couple weeks..Then ill take it in to have the hot and cold side of the turbo done....
09-01-2014, 09:25 PM | #146 |
Re: ls turbo build
Looks like the exhaust manifold on the passenger side will not work with this ac bracket... will any other manifolds work?
09-01-2014, 10:40 PM | #147 |
Re: ls turbo build
maybe run another passenger side manifold and point it down?
or corvette style center exit manifold? |
09-02-2014, 08:43 AM | #148 |
Still Learning
Re: ls turbo build
What manifolds have you tried? I have also seen where guys cut the stock flange off and weld a different type connector or just weld a short piece of pipe and then you can use clamp style connections.
09-02-2014, 12:54 PM | #149 | |
Re: ls turbo build
http://67-72chevytrucks.com/vboard/s...=529064&page=5
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-02-2014 at 01:06 PM. |
09-02-2014, 01:26 PM | #150 |
Re: ls turbo build
Pretty sure Wasted used a Vette manifold (ZOMGVETTEPARTS!!!) on the passenger side with a vband flange welded on.
Sorry Wasted but couldn't resist using the ZOMGVETTEPARTS!!! from your build thread!
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
