Old 08-21-2013, 03:33 AM   #1
draggin49
column or floor shift for my new 700r4???
Ok, I scored a 700r4 for my truck that will be installed soon. My 1969 c10 is an original 3 on the tree manual transmission.
What are my options to make the 700r4 work??
Any way to use/modify the original steering column and run it through there?? Or do I gotta search out an aftermarket column and swap it in.
Just want to find out how difficult /expensive to operate the 700r4 through the column vs just installing a tall lokar shifter.
Thanks guys.
draggin49 is offline   Reply With Quote
Old 08-23-2013, 03:17 PM   #2
draggin49
Re: column or floor shift for my new 700r4???
Bump for more looks...
I was told a factory steering column will NOT be able to be modified to run a 700r4
Is this true??
I priced a tilt column through CPP @ $349
Other option would be a lokar shifter price probably isnt too much cheaper im guessing.
Hmmm , any input /suggestions would be great
Old 08-23-2013, 03:23 PM   #3
jbrignac
I just had mine switched out for a 700R4. Mine was auto to begin with and my factory column works fine with the new one. The guy who did the install told me that I wouldn't be able to put it in low gear with the exisiting column. Since I never use it, I don't see that as an issue.
jbrignac is offline   Reply With Quote
Old 08-23-2013, 03:55 PM   #4
Longhorn 70
Longhorn 70's Avatar
If you get Lokar's adjustable linkage kit it will go into low.
Lookie Here Now for information.
Here are the instructions.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 08-23-2013, 04:49 PM   #5
mgkgmc
mgkgmc's Avatar
Is it true the gear indicator will not match what gear the trans is in though. Do they make a replacement one?
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 08-23-2013, 05:09 PM   #6
draggin49
Hmmmm I wonder if my column /shifter being a manual makes it a no go?
Old 08-23-2013, 05:11 PM   #7
C_Ruiz
Mine had a 4 speed Muncie in it that NEVER shifted into 1st gear.
Swapped in a 700R4 and used a steering column from an 85 van.
Easy swap.
C_Ruiz is offline   Reply With Quote
Old 08-23-2013, 05:58 PM   #8
leftybass209
leftybass209's Avatar
I posted a little DIY thing for a gear shift indicator on a non tilt with 700r4, can be found here... http://67-72chevytrucks.com/vboard/s...d.php?t=519811
leftybass209 is offline   Reply With Quote
