Old 08-21-2013, 09:57 PM   #1
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
Hotchkis TVS and ECE Rear crossmember/trailing arms
Ok here is the situation.
I need some people that have the TVS kit installed to chime in please.
I am looking to order the full TVS kit for my 72. Would also like to upgrade the rear crossmember and trailing arms with the Early Classic pieces.
I have talked to both Hotchkis and ECE and we think they should work together.
The hotchkis kit comes with the blade style rear sway bar that require you to drill and weld a plate to the stock trailing arms. I am thinking of having ECE drill the hole and weld a sleeve in there for the bolt to go through so it all powder coated and ready to go...
The question is... could someone that has installed the Hotchkis kit measure exactly where this hole goes? Either from the middle of the coil spring mount hole OR from the middle of the trailing arm mount bushing hole?
I have called Hotchkis they cant give me the number I am looking for. They did offer to call some customers with the kit installed and see if they could get an answer for me... I thought I would do the same here and then we could compare notes...
I am hoping multiple people chime in and we are close on this measurement.
So... Sorry for the novel but any repies are greatly appreciated...
chevyguy_72 is offline   Reply With Quote
Old 08-22-2013, 02:44 PM   #2
GEARBOXGARAGE
Re: Hotchkis TVS and ECE Rear crossmember/trailing arms
My truck is off at paint, but if I get a chance to get out to the paint shop I'll try to remember to get those dimensions. I'm running the same arms with that sway bar...
GEARBOXGARAGE is offline   Reply With Quote
Old 08-22-2013, 02:48 PM   #3
GEARBOXGARAGE
In the meantime, I found this pic saved on my computer, it may help...
Old 08-22-2013, 03:01 PM   #4
chevyguy_72
Vintage Evil
appreciate the pic.
Old 08-22-2013, 03:55 PM   #5
chevyguy_72
Vintage Evil
Would really appreciate it if you can get the measurements. Did you just drill yours?
Old 08-23-2013, 02:34 PM   #6
GEARBOXGARAGE
Drilled oversize and welded in DOM Tubing. Then I scuffed the powder coat and painted with Eastwood Extreme Chassis Black Satin. Matches the powder coat great, but probably not as durable as the powder coat.
Old 08-26-2013, 10:10 AM   #7
chevyguy_72
Vintage Evil
Anyone else with this kit installed?
Old 09-15-2013, 08:31 AM   #8
GEARBOXGARAGE
I've got the measurement for the hole location... Only took me 3 visits to the painter's to remember.... Measure back from the center of the 3/4" bolt hole at the front of the trailing arm to 34-3/4". This should give you an approximate alignment to the center hole on the sway bar, as there are 3 holes to adjust its stiffness.
Old 09-17-2013, 02:29 PM   #9
chevyguy_72
Vintage Evil
Thanks man
Appreciate it...
