Old 08-24-2013, 02:29 PM   #1
cameyer
Bouncing gas guage
So I have finally finished installing my under bed gas tank from lmc and have it filled up however I have found the gas gauge bounces around a lot. Since my gas guage never work I don't know if this is normal for this truck so hopefully some one can help. The gauge fluctuates as much a quarter of a tank when I go over bumps
cameyer is offline   Reply With Quote
Old 08-24-2013, 03:49 PM   #2
Sharps40
Re: Bouncing gas guage
Normal. Enjoy it, it works!!!!! Gotta buy 2013 cars for a steady gas gauge.
Sharps40 is offline   Reply With Quote
Old 08-24-2013, 05:12 PM   #3
NCD1966
NCD1966's Avatar
i'll take a bouncy one anyday; mine just pegs out pass full all the time.
its not an old sending unit and its not stuck either (i checked)
not sure whats the deal
1966 Chevy C10 Stepside 355ci sbc with 3speed OD
2021 GMC Sierra 1500 AT4 6.2
1980 Chevy Camaro z28 383ci
1990 Chevy Suburban 350 tbi 2x4 (sold)
1984 Chevy C10 sliverado short fleet
1997 Chevy C1500 short fleet
NCD1966 is offline   Reply With Quote
Old 08-24-2013, 05:49 PM   #4
VonDog
VonDog's Avatar
Sounds like the contact inside the sending unit control box is stuck! I yanked mine out cuz it didn't work at all and found that the box had broken open and the copper inside the wasn't making contact so I soldered it back together, made sure the contact was positioned right, and soldered the small box back together, installed and everything works now. Good luck!
VonDog is offline   Reply With Quote
Old 08-24-2013, 06:41 PM   #5
yelmer
some of the after market sending units use the wrong ohms? current to the gauge . if you can find a original good unit might be the way to go if you are having problems .
yelmer is offline   Reply With Quote
Old 08-24-2013, 06:44 PM   #6
Sharps40
Maybe 0 to 90 ohm sender on a 0 to 30 ohm gauge....?
Old 08-24-2013, 06:48 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
When it stops bouncing, that means to look for a gas station.... QUICK!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-24-2013, 07:05 PM   #8
cameyer
The sending unit is brand new. I didn't look very closely at it just popped it in should u take it out an examine it? I have the bed off right now so I'm trying to get everything perfect before the bed goes back on
Old 08-24-2013, 08:25 PM   #9
VonDog
VonDog's Avatar
I would pull it before you put the bed on and check it with a meter while you work the float!
Old 08-24-2013, 10:43 PM   #10
jtrichard
NCD 66 ...with the key/INJ. on ground out the wire at the sending unit and see if dash gauge goes to E if it does then its the sender if it still stays at F then you have an "open" wire to the dash gauge
jtrichard is offline   Reply With Quote
Old 08-25-2013, 02:27 PM   #11
hotrodder
Does the tank have a baffle in it? The fuel sloshing around can cause the float to bob around until it settles down.
hotrodder is offline   Reply With Quote
