Old 08-25-2013, 08:59 AM   #1
chevy-fun
chevy-fun's Avatar
bolt on 4 link coilover??
84 c10 long bed currenty with 4" drop shackle hanger
Been looking at performanceonline bolt on 4link(pic). Also see brothers seems to carry the same one. Does anyone have any reviews on it. Rob at nolimit carries the fatbar coilover but seems to be a complete weld on. Does he offer a bolt on? Both pol & brothers have the coilovers mounted inward. While nolimit mounts on outside up an down. Any advantages??
chevy-fun is offline   Reply With Quote
Old 08-25-2013, 09:13 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: bolt on 4 link coilover??
Doesn't really appear bolt on to me.
The coilovers are so close together,... that the link bars would have to be mounted inboard of the frame rails.
If that's the case,... the front link bar brackets are backwards in that picture.
Shock bridge and axle tube mounts are weld-on.
Looks to be for a "pro-street" set-up only.
Step notched frame would have to be built.
Wth the low hanging 4-link bars,... I assume a pretty tall ride height would be the end results with a 31"-33" tall rear tire.
Keith
Convert to disc brakes.
Old 08-25-2013, 12:03 PM   #3
chevy-fun
chevy-fun's Avatar
I know the axle brackets need be welded. Guess I meant with least amount of welding. An from pol n brothers said it mounts on the outside. Think the pic just makes it look close together. Hope someone is able give a review or Rob comes in an gives some input. This is a dail driver with spirited driving an going track once in awhile when done. Right now its on 17" tt2s on 28tire.
Old 08-25-2013, 12:06 PM   #4
chevy-fun
chevy-fun's Avatar
An about it hanging low. Doesnt seem any worse as people running shock extenders
Old 08-25-2013, 12:48 PM   #5
tinydb84
tinydb84's Avatar
It looks low to me. The shock extenders are located directly under the axle so its less likely to get caught up. kp sells a complete bolt in 4 link just not with coil overs
David
Instagram: myfabguy
Old 08-26-2013, 01:41 AM   #6
andrewmp6
How you feel about air bags?Ridetech has a nice bolt in 4 link kit for the rear.If your heart set on a 4 link and coilovers get one welded in,Both scotts hot rods and nolimit have nice weld in kits.
Old 08-26-2013, 09:09 AM   #7
chevy-fun
chevy-fun's Avatar
I had a 78 that had ridetech all around. This go im looking to go coilover.
Old 08-26-2013, 09:11 AM   #8
SCOTI
SCOTI's Avatar
Ride Techs rear 4-bar kit can prob utilize their coil-overs too.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-26-2013, 09:57 AM   #9
chevy-fun
chevy-fun's Avatar
Ima make a call to nolimit and ask about there fatbar coilover kit. See if they have a bolt on with minium welding. If not I'll go ahead an try pol. Not trying to go over $1300 would also like to buy set of rims
Old 08-26-2013, 12:11 PM   #10
SCOTI
SCOTI's Avatar
POL's stuff is usually manufactured by others w/the middle-man mark-up. It looks like their kit is No Limits w/a mark-up (read the tech text for each).
KP Components (a chris alston company now) also makes a bolt-in 4-link (part of the 6-link set-up & can be purchased separately). You'd just have to do the weld-on mounts for the coil-overs....
https://www.cachassisworks.com/p-253...uspension.aspx
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-26-2013, 12:44 PM   #11
chevy-fun
chevy-fun's Avatar
Scotti i did check kp stuff out the other day. But after having to peice all the parts together , kit, panhard bar an coilover. Felt wasnt worth it. But i did like how it mounted to the axel. If i ever wanted to return to stock it be simple to take off.
I did call nolimit an may go with them. Going to call back in a bit as i got a few more Q's to ask them
Old 08-26-2013, 02:24 PM   #12
tinydb84
tinydb84's Avatar
Have you thought about a weld in kit? I am having a local shop weld one in for me. It is a lot cheaper than I had expected ($300 if I supply all the parts; thought I am having him do a lot of work so he gave me a good deal).
David
Instagram: myfabguy
Old 08-26-2013, 02:56 PM   #13
chevy-fun
chevy-fun's Avatar
Well kinda wanted a bolt on kit in case i ever decide to sell an put back to stock. I never thought about taking it to a shop to have it welded.
Old 08-26-2013, 05:55 PM   #14
tinydb84
tinydb84's Avatar
I would think that a 4 linked coil over set up would be worth more than selling it stock. Look around online and see if there is a shop that does work for the local car clubs. I found that those places tend to be the least expensive and you can see their work at local shows.
David
Instagram: myfabguy
Old 08-26-2013, 10:34 PM   #15
Ricos54
Ricos54's Avatar
Don't know if you know this, but the 4 link are great for straight shot. But if you plan on everyday driving the 4 link is not the best way to go. I've heard the 4 link makes noise going around corners. Also coil overs do not ride as nice as leaf springs. It looks bad ass, but not the best ride.
Just my 2 cents
Ricos54 is offline   Reply With Quote
Old 08-26-2013, 10:59 PM   #16
chevy-fun
chevy-fun's Avatar
Not what I wanted to hear. But good to know. Why I was hoping someone had some reviews on them
Old 08-26-2013, 11:06 PM   #17
Ricos54
Ricos54's Avatar
Believe me, I know what you mean. I've been doing nothing but research. I wanted 4 link so bad. After learning that, I read about 2 link, but it's still the same. You have one spring with the coil controlling everything. With the leaf spring you have all those leafs! When the truck compress's the extra leafs kick in and that is why the ride is so much better.
So now I'm trying to find the right leaf setup in the rear to lower my truck with the mustang in front to get the best ride possible.
Rico
Old 08-26-2013, 11:48 PM   #18
tinydb84
tinydb84's Avatar
Just my 2 cents
No offense but have you driven a 4 link?
I daily drove my brothers 74 short bed that was bagged on an air ride technologies 4 link with sleeve bag behind the axle and it rode better than any other leaf spring vehicle that I ever drove. Granted it wasnt coil over but I have driven coil over cars that rode anywhere from gokarts to luxury cars.
David
Instagram: myfabguy
Old 08-27-2013, 12:23 AM   #19
Ricos54
Ricos54's Avatar
This was coming from the companies that sell The 4 link setups. They all told me that leaf would give a better ride.
Old 08-27-2013, 10:30 AM   #20
SCOTI
SCOTI's Avatar
Don't know if you know this, but the 4 link are great for straight shot. But if you plan on everyday driving the 4 link is not the best way to go. I've heard the 4 link makes noise going around corners. Also coil overs do not ride as nice as leaf springs. It looks bad ass, but not the best ride. Just my 2 cents
Maybe a factory leaf set-up rides better vs a race 4-link type set-up (race 4-link = heim joints, inboard springs, narrow width between the bars, etc...).
Leaf suspensions in the 67-87 swb trucks do not ride better vs coils in an apples to apples comparison. They do offer a more stable load support since the springs are outside of the frame rails. But, a properly set-up 4-bar (poly, swivel, or rubber bushings w/limited adjustability) & the right length coil-over would work well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-28-2013, 09:25 AM   #21
king-918
king-918's Avatar
Your not going to want to go back stock, as far as riding rough it depends on how you set it up. but by nature they are not a bad or noisy ride, most stock trucks are going with some type of 4-link now
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 09-10-2013, 11:38 PM   #22
Ricos54
Ricos54's Avatar
I've been talking to more pro's on the subject and they told me if a 2 link was setup correctly it could give a better ride than leafs or 4 link for everyday driving, so I decided to go for it. I just got my Mustang II welded in an I'm going to get my motor mounts welded in the end of this week then I'll be installing the 2 link with some high end coil overs from component engineering. If I do all the work myself it should cost around $400. The part I will like is I will be able to adjust my ride height. Well see it go's
Old 09-11-2013, 01:15 AM   #23
tinydb84
tinydb84's Avatar
I dont know how it would give a better ride than a 4 link but as long as you are happy more power too you. Lets see some pics
David
Instagram: myfabguy
Old 09-11-2013, 02:25 AM   #24
mongoose
mongoose's Avatar
no offense... but where are you getting this info from? who are your pro's? the local mini truck guys? i seem to get wonderful info such as since im running bags i don't need shocks etc..
a 2 link is less than ideal unless it's converging like 67-72.. leaf springs ride like crap.. a 4 link has been the best idea so far.. a tri 4 link is one of the best things to put in a car and truck.. minus maybe a 3 link or IRS. and a coil over is nothing more than what 99% of cars and light trucks are being fold with these days..
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-11-2013, 03:17 AM   #25
andrewmp6
2 Link depends what they are talking about,The truck arm set up is fine a parallel 2 link no way id run that.A 4 link if set up right will handle pretty good a lot of cars have kinda a triangulated 4 link stock like gm A body,B body,G body and the fox body mustang.A 3rd/4th gen f body used kinda a 3 link and they handle pretty good as well.
