Old 08-25-2013, 12:26 PM   #1
54blackhornet
54blackhornet's Avatar
12V to Coil ? Non HEI
I ripped the entire wiring harness out of the 71 K-10 this week, I have never seen such a hack job before ? The PO installed a 110 Inverter to power a camper and it fried the harness . Yesterday I installed a good + and - battery cable, and ran a jumper wire to S terminal on starter to see if engine would turn over ? It did Whoopie ! Question, Can I run 12V straight to coil to see if it will run ? Or do I need to step it down to 9V ? If so How ?.....Thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 08-25-2013, 12:45 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 12V to Coil ? Non HEI
Yes you can test it at 12 volt. It usually takes a few hours of running before the points burn up. DAMHIK
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-25-2013, 12:57 PM   #3
54blackhornet
Thanks Bigdav , I guess I will have a project today
71 C-20
07 Magnum RT AWD
Old 08-25-2013, 02:06 PM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
I had a '70 Bel Air with a 250 and points ignition. Ran great for years and then it started cutting out at high rpm. I mean, you'd be merging onto the highway with the six pumpin' for all it was worth and it would just die.
Pull over to the side and it would fire up and drive again - as long as you stayed away from the high end.
After much trouble shooting, we hooked a meter to the coil and went for a drive. Voltage stayed around 7 during most driving but spiked to 12 during high rpm. It turns out the resistor wire was getting old and shot.
I solved it by dropping an HEI in and running 12 volts to the coil...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 08-25-2013, 04:51 PM   #5
Wrenchbender Ret
It would be best to hook a resister in the wire going to the coil. You can buy one for the late 50,s cars or trucks for a few bucks. It will save damaging the points & possibly the coil.
Wrenchbender Ret is offline   Reply With Quote
