08-25-2013, 09:45 PM | #1 |
motor wants to stay on
I have a 86 chevy k10 when I turn the truck off the motor acts like it wants to stay on, like it will turn over a few times after I turn the ignition off. is that the carb? it has a stock quadrajet on it and what size cfm is it to? thanks for the help.
08-25-2013, 10:00 PM | #2 |
Re: motor wants to stay on
I'm sure someone that has a lot more knowledge then I will jump in...but I would check the "anti-dieseling" solenoid on the carb if the truck has one, or the timing may be off slightly.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
08-25-2013, 10:03 PM | #3 |
Its called dieseling...what rpm does you truck idle at? Could be too high
Posted via Mobile Device |
08-25-2013, 10:08 PM | #4 | |
-Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 Last edited by SamsAutoParts73-87; 08-25-2013 at 10:08 PM. Reason: typo |
08-25-2013, 10:15 PM | #5 |
I'd start with timing. To far advanced will cause a diesel. Crappy gas and high compression will do that too and comes with a spark knock
08-25-2013, 10:45 PM | #6 |
Turn your idle down. If it idles too slow then just hook your vac advance to manifold vacuum to speed it back up.
