Old 08-26-2013, 10:04 PM   #1
Dads64
Clutch???
I have '64 C10 long bed that I bought as a parts truck that wouldn't idle when I got it. It's a 6 with 4 speed and it would drive/shift just fine but you had to stay on the gas. We drove it last in December and it drove fine but this weekend after I got it to idle and run smooth, it will not go into gear. The clutch seems to be not releasing. If I have the clutch to the floor and the truck in gear when trying to start it, it will drive LOL.
Any ideas on what my problem might be??
Thanks,
Jay
Dads64 is offline   Reply With Quote
Old 08-26-2013, 10:35 PM   #2
bama63
bama63's Avatar
Re: Clutch???
clutch frozen (rusted) to flywheel have some one depress the clutch and use a pry bar or screwdriver to separate it.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 08-27-2013, 09:52 AM   #3
luvbowties
luvbowties's Avatar
Thumbs up Re: Clutch???
Bama63 could have the answer. Also, If manual clutch, adjust clutch linkage? If hydraulic clutch, check fluid level--also, another quick check: with eng. running, in neutral, pump pedal several times and see if it goes into 1st or reverse easier; if so, the clutch master could be bad.
sam
luvbowties is offline   Reply With Quote
Old 08-27-2013, 10:59 AM   #4
billd5string
billd5string's Avatar
Re: Clutch???
I recently had my clutch disc come apart, and the the disc springs wedged in between the disc and the pressure plate. Everything looked fine externally, but it acted just like you describe.
If the disc came apart like mine did, or rusted to the flywheel like Bama63 suggests, either way, just pulling the transmisison and having a look will tell you exactly what's wrong.
That's not the easy answer though, sorry.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 08-27-2013, 04:36 PM   #5
fleetweld47
Re: Clutch???
I agree with the above reply's that the clutch is stuck to the fly wheel . I would first try to push/pull the truck while it is in gear and the clutch depressed all the way down with another vehicle. If that does not work you can always take a good pudy knife that is really thin and tap in between the clutch disc and fly wheel from the bottom as your rotate the fly wheel (Just make sure the ignition is disengaged ). Hope this helps as I have had to do it many times.
fleetweld47 is offline   Reply With Quote
Old 08-27-2013, 07:31 PM   #6
Dads64
Re: Clutch???
Thanks a ton guys! It is a manual clutch, I got under and lightly worked at it with a screw driver. It didn't work at first but after getting pissed and stomping on then letting the clutch pop back, it started shifting perfect.
Thanks again,
Jay
