08-28-2013, 10:59 AM | #26 | |
Re: Recommend carb for 5.7 350
As far as timing I have no clue on what it is set at, I'd need to get a timing light to find out or if there is another way to figure this out let me know. There is a bit of a smell of gas in the exhaust so I believe that means it is running rich?
'72 GMC Super Custom 1500 350 V8 w/AC |
08-28-2013, 11:00 AM | #27 | |
08-28-2013, 11:32 AM | #28 |
With the lack of a working choke it will be a bit cantakerous starting.
You could get a timing light and check it. Rich smell in the exhaust could just be lack of good hard use. You gotta blow the carbon out once in awhile. If it runs good otherwise then why fuss with it. If you want to learn how to check the timing just ask! |
08-28-2013, 11:48 AM | #29 |
Yeah it is running fine like it has been. If no one had mentioned about the 2 barrels not working I would have never known.
It would be nice to eventually fix it to get it starting smoother but not a major concern. I suspected the choke was not working properly after talking with a friend who has a manual choke on his old chevy, but assumed it was automatic so never looked into it further. I'll read up a bit more in the book and look at the choke and the linkages. So, how would one learn how to check the timing?
08-28-2013, 11:56 AM | #30 | ||
"I ain't nobody, dork."
You need to know what is in the engine. A rough idle coulld mean a bigger than stock camshaft. Stock timing was around 8 to 10 degrees advanced before top dead center (BTDC).
Like I stated in your other thread... you NEED a timing light to get the timing nailed down before diagnosing any carb problems. Timing lights are a very important tool to have when working on old rigs. They aren't expensive either. Also... a good service manual (Chilton, Haynes) will give all the tune up specs. Gary
08-28-2013, 12:09 PM | #31 |
Simple.
Just google 'how to set timing on a sbc'. Lots of sites come up. There's some threads on here and a write up in the FAQ section. If it's set to stock timing it will be set at 4-6 degrees. With the crap gas we buy now you can bump it up to 12. Don't get caught up in the discussions about recurving your distributor. Just look for how to check your basic timing. |
08-28-2013, 12:10 PM | #32 |
Alrighty, I'll go ahead and finally get a timing light than. I have the pdf copies of the service manual that have been posted on here as a reference but will get a Chilton/Haynes service manual as well.
08-28-2013, 02:08 PM | #33 |
I hate Holleys! Yes they are easy to modify and parts are readily availible for them. There is a reason for that.
Q-jet's are the best for street use as stated earlier by other members. In the right hands a Q-jet is nearly unbeatable. GET a new mechanic. You carb does look like a aftermarket rebuilder has had it recently. As such, the problem might lie with the Secondary air flap adjustment tension. On the right side of the carb where the airflap shaft come through the body... underneth this is a little allen head screw that adjusts the tension on a spring. MAKE small adjustments and road test. You should have a smooth and gradual, but very noticable increase in power and throaty noise. Not a big kick in the pants or slow transition.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
08-28-2013, 02:17 PM | #34 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-28-2013, 03:59 PM | #35 | |||
Holleys are less complicated than a Q-jet... but everybody makes them out to be a nightmare. Very easy to tune, and completely reliable. Most are dang near spot on out of the box. The old wives tales that you have to constantly tune a Holley are just not true. Gary
08-28-2013, 04:44 PM | #36 |
The old wives tale that you have to constantly tune any carb is the one that makes me laugh Gary!
08-28-2013, 09:47 PM | #37 | |
08-28-2013, 10:36 PM | #38 |
With your choke not working properly, the mechanism that allows the secondary's to open is also not working properly.
Fix that, or remove it, and you will enjoy the moan of that Q-jet like never before.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
08-28-2013, 10:46 PM | #39 | |
I have a radical idea!
With that being said, that doesn't make them "better". The smallest cfm Q jet is capable from flowing 750 cfm, IF the engine needs it, but most small blocks don't. Besides appearance, there's no advantage whatsover to any Holley vacuum secondary vs a Q-jet. Most people (including myself) think the Holley's look better or more impressive, especially a dual line Holley. The bottom line is if you are using a vac secondary Holley on an engine, you are leaving economy and power on the table. The notion that a Q-Jet is only suited for a stock or low HP application is laughable. It takes a 750 double pumper to start getting close to a well tuned Q jet. Pontiac, Olds, and Buick guys have a tons of naturally aspirated 10 and 11 second cars with Q-jets. I have a 800 cfm Q Jet (straight inlet Buick carb, actually) that I am going to run my on my '67 GTO that I used to use on a street/strip '69 Firebird years ago. I was running it on a Performer RPM intake on a healthy 440 cu in Pontiac (.060" over 428). My brother bought a new Quik Fuel 750 chokeless race carb when they came out, and we tried it on my Firebird. The 2 carbs ran .006 apart. It 60 ft'd better with the Q-Jet and ran a 1/2 MPH faster in 1/4 with QF. This was $600+ Race race carb vs a re-jetted stock Q-jet with choke flap still installed. I'm not trying to be a Holley basher - I've ran tons of them, but its hard for me to put a Holley double pumper on a street driven engine with gas being $3.50 a gallon, and I am going to put a Holley vacuum secondary carb on an engine and give MPG AND power. When gas was cheap, I'd run the double pumpers on street cars, but I can't see doing that anymore unless its a just a toy ot street/strip car...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
08-28-2013, 10:51 PM | #40 | |
He's good to go. |
08-28-2013, 10:55 PM | #41 |
Moderator
08-28-2013, 11:03 PM | #42 |
I have never messed with an electric choke model, looks like it is still on the carb though...but with my old eyes I cant tell what's what in the pics.
08-28-2013, 11:08 PM | #43 |
Cheese should not go on a turkey sandwich.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives Last edited by slow-1; 08-28-2013 at 11:24 PM. Reason: Reconsidered being a smart a$$ |
08-28-2013, 11:21 PM | #44 | |
Just put a Predator on it and be done with!!! -lol
08-29-2013, 12:06 AM | #45 |
Well this has turned into quite an active thread. I probably should edit my original post to say that now I am looking for help to fix the carb. Not looking to buy a new one or get a replacement.
Honestly this is the first carburetor engine I have worked on so all of this new to me. I want to learn so I can do all of this stuff myself. I'll keep on reading up on stuff to learn more. Here are some more pics to see if you point out what is not hooked up properly.
08-29-2013, 12:20 AM | #46 |
Only thing I see wrong or out of place is the old choke stove and linkage rod still attached to your intake manifold. It might hang up your linkage so best to remove it. Should be a large phillips head screw that's easy to unscrew and remove it.
If you intend to make your choke work you'll need to run 12V to the black cap. To set the choke you loosen the 3 screws that hold the cap in place and rotate the cap. Hold the throttle open as you turn the cap and the choke plate will close. Here's a link that explains your carb and choke. http://www.vetteprojects.com/kstyer/quadrajet.htm |
08-29-2013, 12:45 AM | #47 |
Ok I thought it would need 12V. I assume it only needs 12V during ignition correct? I will run a 12V unfused ignition wire to the black cap. I should have one of those type of connections somewhere as I remember seeing lots of loose wiring underneath the hood not connected up at all. I think the PO forgot to hook it up.
08-29-2013, 10:49 AM | #48 |
The shaft at the bottom rear of the carb that goes all the way to the other side is the secondary shaft, it has the pin that almost looks like a finish nail in it. Just in front of that there is a brass piece that is blocking that shaft from rotating, and is why your secondaries (second 2 of the 4 barrels) won't work.
Once you get the choke either working or removed, I bet the secondaries will work fine, looks like a recent rebuild. This book was a big help to me with its diagrams of how things should be and explanations of how to get them that way. http://www.walmart.com/ip/4890091?wm...599990&veh=sem
08-29-2013, 11:38 AM | #49 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
08-29-2013, 11:49 AM | #50 |
Some more good links.
Read carefully John. There will be a test. LOL! http://www.carburetor-blog.com/free-...epair-manuals/ http://www.buickpartsdirectory.com/carbs.htm http://www.digitalcorvettes.com/foru...ad.php?t=88376 |
