Old 08-28-2013, 06:25 PM   #1
Billett
Billett's Avatar
Driveshafts
What are you guys running with the swaps? I have a mild 6.0L with a 4l80. I was quoted $300 to resize the stock driveshaft, add "performance u joints" which I would hope are the 1350s, and replace the carrier bearing. I feel like for that much I would rather spend a bit more for a new one. I'm not going carbon fiber as nice as that would be, but I'm thinking a one piece aluminum or chromoly from PST right now.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 08-28-2013, 07:23 PM   #2
truckdude239
truckdude239's Avatar
Re: Driveshafts
I paid 60 dollars to shorten mine plus 40 buxs for u joints and 20 for a new carrier bearing
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-28-2013, 09:50 PM   #3
Billett
Billett's Avatar
Re: Driveshafts
Damn. Looks like he's trying to rip me off big time. Thanks for the heads up
Will
2024 Toyota Sienna
Old 08-28-2013, 09:58 PM   #4
Blackpony
Blackpony's Avatar
Re: Driveshafts
The driveshaft shop I use, quoted me $125 to rebuild my stock driveshaft. That includes ensuring it is straight, balancing it and installing heavy duty u joints. Or $250 for a new steel shaft or $375 for a new aluminum shaft.
Blackpony is offline   Reply With Quote
Old 08-28-2013, 11:20 PM   #5
71chevystep4x4
71chevystep4x4's Avatar
Re: Driveshafts
Mine was $118, dropped it off in the evening, and it was ready the next day. They even painted it and put a sticker on it. Obviously it depends on what shop you take it to.
71chevystep4x4 is offline   Reply With Quote
Old 08-28-2013, 11:25 PM   #6
Billett
Billett's Avatar
Re: Driveshafts
It looks like I may just be finding a different shop. I just took some measurements and it looks like its 41" from the rear u joint to where the carrier bearing mounts to in front of the cross member, but 71" from the rear to the flat of the trans.
Just under 6' is pretty long for a driveshaft... I'll call PST tomorrow to see what they think.
Will
2024 Toyota Sienna
Old 08-28-2013, 11:32 PM   #7
Blackpony
Blackpony's Avatar
Re: Driveshafts
It seems that way, but the new chevy, ford and dodge trucks all come with a one piece usually aluminum ds. If you get a long bed crew cab, those suckers are close to 7' long!!
Old 08-29-2013, 12:21 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Driveshafts
I paid about $140-60 for a custom length shaft with the correct ends, built thick wall (rated to 800+hp) with performance (read non-zerg) u joints.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-29-2013, 02:07 AM   #9
truckdude239
Re: Driveshafts
They had me measure from the stub stinkout out of tran to the center of the first bolt hole onine
David fuller
2000 Tahoe 5.3l 378
Old 08-29-2013, 07:25 AM   #10
Billett
Billett's Avatar
Re: Driveshafts
Brew city, did you get yours done locally? Also did anyone need to clearance the cross member for a larger diameter shaft? My is only lowered about 2", so the angle shouldn't change much.
Will
2024 Toyota Sienna
Old 08-29-2013, 10:19 AM   #11
Billett
Billett's Avatar
Re: Driveshafts
Apparently PST won't make me a one piece from steel or aluminum that's 6' long. Their two piece steel was $550. Looks like I'm on the hunt for another shop...
Will
2024 Toyota Sienna
Old 08-29-2013, 12:24 PM   #12
Jon01
Jon01's Avatar
Re: Driveshafts
My new shaft was $300 stem to stern.
If you do go 1pc you will probably need to remove the mount for the carrier bearing that sticks down from the x-member or it might rub under suspension compression.
It's an easy job with the air chisel or plasma cutter.
Jon01 is offline   Reply With Quote
Old 08-29-2013, 02:35 PM   #13
Billett
Billett's Avatar
Re: Driveshafts
Yeah I was planning on it if I went one piece but I don't think I will. I found a shop that will rebuild and cut mine for $140, but a one piece would be in the high $300 range from there. I don't think I'm running enough power to warrant anything more than stock steel with stronger joints. I like to do it right the first time but in this case I'm already almost 2 grand over where I wanted to be with this project. I'm just glad this is the last major thing I need to buy.
Will
2024 Toyota Sienna
Old 08-29-2013, 05:19 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Driveshafts
Mine was made by A1 driveshaft in Milwaukee. Its a sh!thole in the hood but damn they can make a beefy shaft.
Mine is lowered well over 4" and I have no clearance issues. The shaft is not noticeably larger, i think the wall thickness is "inward", meaning the I.d. would be smaller if you cut it ope, but the wall thickness is greater
Old 08-31-2013, 09:15 PM   #15
Blackpony
Blackpony's Avatar
Re: Driveshafts
I measured the factory driveshaft on a new dodge 1500 yesterday. It is factory aluminum and measures 71'' center of cap to center of cap. Might be able to find a used one and get it cut down...
Old 09-02-2013, 07:49 PM   #16
Billett
Billett's Avatar
Re: Driveshafts
That's awesome to know. The shop I dropped it off at is giving me a quote tomorrow so if its still as steep as the other place I'll keep that in mind.
Will
2024 Toyota Sienna
